Design me a fuel pump system
Results 1 to 14 of 39
    Senior Member David_396's Avatar
    Hanford CA
    Default Design me a fuel pump system
    I have a Aeromotive 11101 pump and filter Assembly. Have blown BB. Thinking I need a fuel return to two tanks and a Boost referenced fuel regulator?? Any help would be appreciated thanxs david.
    Part Number:AEI-11101Free Flow Rate:600 lbs./hr.Maximum Pressure (psi):90 psiInlet Size:-10 ANInlet Quantity:SingleInlet Attachment:Female threadsOutlet Size:-10 ANOutlet Quantity:SingleOutlet Attachment:Female threads
    waterloo
    Quote Originally Posted by David_396 View Post
    This will be totally cool and $$$
    Wags
    waterloo
    Why do you need to return to two tanks?
    I had twin tanks in a river blown jet piece. The easiest way to run was a gauge in one tank. A transfer pump (small) in the secondary tank. When sitting and having a beer, turn on the transfer pump, watch the gauge. Worked pretty easy.
    That way, return fuel to only one tank.
    Boost referenced regulator? Gas I assume? Why. Keep fuel pressure up (no problem with that pump), properly jet, and go for it.
    Wags
    waterloo
    Or is this an electronic FI peice. I assumed carbs. Maybe not
    Wags
    Hanford CA
    Or is this an electronic FI piece. I assumed carbs. Maybe not
    Wags
    8-71 twin dominators on gas. Has two SS 20 gallon saddle tanks. The current way too small mechanical pump draws out of both tanks simutaniously although it has two sending units?? thought if I get fuel from both tanks I could return it to both tanks through a distribution block to keep tanks ballanced. Do I need a boost referenced regulator?? I'm all ears to advise. thanxs david
    Senior Member Red Rocket's Avatar
    winchester, ca
    Just plumb the return line back to the feed line in front of the pump. I have been running the same pump on my twin turbo motor and have it set up this way. Just put the return line as far as possible away from the pump inlet.
    Cantard 71hallett's Avatar
    snow bank
    No you dont need a boost ref regulator. Reference is need only to compensate for blow through pressure that counters the fuel pressure. 1lbs of boost = fuel pressure increase of 1 lbs exc.
    snow bank
    Quote Originally Posted by Red Rocket View Post
    I have been told this can airate the fuel.?
    winchester, ca
    I have run this for 4 years, but that is why I said to tie into the feed line well in front of the pump.
    snow bank
    I hear ya.
    I would say the 13204 reg would be your choice. my .02
    You can leave the ref port empty.
    winchester, ca
    I don't remember the part number for my regulator, but yes leave the reference port open don't cap it just leave it open
    MI
    Just split the return line back to each tank. I'm using -10 into regulator. -8 out of regulator into a -6 tee. -6 back to each tank.
    Hanford CA
    My current setup has a line from each tank to a T-fitting then directly to the pump. There wouldn't be much distance after the T before the line goes into the pump.
    snow bank
    Quote Originally Posted by sanger rat View Post
    You idea is 100%
    Be alot nicer if he used the 11202 and a standard 4 port reg for his dual carbs though. Problem with that pump is killing 40 sum psi through a regulator.
