Just curious, how much torque does it take to...
Results 1 to 14 of 17
    Default Just curious, how much torque does it take to...
    turn over your engine ?
    Just finished you the Winterizing project. After all the rocker's were backed off I put a torque wrench on the engine to turn it over. Pump disconnected and alternator off; it took 41 lbs. ft of torque to turn over the 565" engine. It's a pretty cool day in El Cajon today.
    Have you ever turned your engine over with a trq. wrench ?
    Sleeper CP
    Big Inch Ford Lover
    Cantard 71hallett's Avatar
    snow bank
    Not with the rockers off and the plugs still in.
    That's funny, I don't recall if the plugs were in or not..... I guess I'll go check.
    I'll get back to you on that.....
    Sleeper CP
    snow bank
    Sleeper CP
    I did that once....... lol
    You're in good company.... make that two of us. But I'm not sure how many were in
    With all of them out it was 30 ft. lbs of torque to turn over ,but it's a cool day (58*) and there's Lucas oil stabilizer in the system.
    4.6" bore, 4.25 stroke, with Total Seal zero gap rings standard tension.
    Sleeper CP
    Sleeper CP
    17 to 20 lbs without the heads on, so I would say you are in the safe area. IMLAO. M
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    it takes more know then it did before
    Quote Originally Posted by 78CoLeBBF View Post
    Would you like to explain ????
    Oh, because of your valve springs, got it, with mine (rocker's) bolted down it's a bunch, but I did pull about 75-80 psi open pressure off the over the nose # last year. Didn't need that much psi with the Ti intake's. I'm thinking about bumping them back up next year when I drag her to the track just in-case I need 350hp worth on Nos.
    Sleeper CP
    Me too
    Sleeper CP
    Me too
    Sleeper CP
    Hey Sleeper, Just keep spinning it and your'e rings will be seated. Just kidding with you. M
    snow bank
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    I have an unfired 509 ( 4.500X 4.00) on the engine stand.
    If I can remember I will check it tomorrow.
    Jim
    Green Bay Wi,USA
    What is special about the Lucas oil stabilizer that it would make the rotation of the assembly different? More slick?
    Less slick.... it's pretty tacky, not sure how much it would add to the rotational friction but it doesn't make it easier. I put it in for the Winter so it would stay on the bearings,roller lifters and rockers. Put in two quarts and ran it for about 20 minutes a few weeks ago.
    Not even sure if it's measurable though ?
    Sleeper CP
