Whipple SC kit
Results 1 to 6 of 6
Whipple SC kit
    Nov 2008
    Default Whipple SC kit
    ok i have a 1994 30' conquest enforcer with a 502 and bravo 1drive, when i bought this boat it came with Whipple SC Kit for a 93-97 502EFI that the prevoius owner had but never installed. It comes with everything needed to install plus a ECM heres the webpage .......... http://www.whipplesuperchargers.com/...sp?ProdID=1148
    this is the style that mounts off the spark arrestor on the side of the engine, not the traditional top mount. well long story short, does anybody have any experience good or bad with these setups, any info would help. And yes i will be upgrading the drive at the same time
    Nov 2008
    my main concerns are the fuel system since mine is a VST, and what are my options to upgrade if i even need to? Also do i need higher PSI injectors? Also i have MEFI-1, but it comes with a new ECU so is it still MEFI-1 or has it been upgraded to a MEFI-3 idk, and how would i find out? Thx for the help
    not ****** little squirt's Avatar
    Waikiki, HI
    Not sure either but you can get a wealth of knowledge and helpful answers if you check out offshoreonly.com and post this up in their forums. i have seen alot of people over there with these setups. good luck
    PASO ROBLES CA cougar63's Avatar
    PASO ROBLES
    Sent You A Pm,can Tell Ya All About Em!
    Nov 2008
    sent u a PM
    rollin on the river DAVEO's Avatar
    Oakley, CA
    I have the same set up in my storage. its polished the innercooler,whipple and plennum. High flow injectors ecu and 5psi and 7 psi pullies Have everything to hook it up. If anyone would be interested. Im looking to sell the whole thing.
