Engine Builder's Fault
Results 1 to 14 of 41
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Default Engine Builder's Fault
    Posting this for interesting discussion and nothing else........................
    So a guy builds a pair of nice 10:1 pump gas 540 long blocks for a pretty nice 33' cat.
    The boat owner dresses the engines, stabs the distributor, puts his own fuel system on etc. installs the engines. Engine builder tells him to run about 34 degrees of timing.
    Third time out burns a head gasket in one of them.
    Engine builder goes over with his timing light and finds 60 degrees of timing 35 degrees of initial timing and a 25 degree advance bushing in MSD distributor.
    The engine owner is wanting to know if the engine builder is going to "stand behind it"
    Hmmm........
    Sounds like he is lucky he doesn't have holes in the pistons.
    I try to stress how to check "total" timing with any engine I built and sell for someone else to install. Sounds like his 35 initial was close to the 34 you recomended, but he had no clue about bringing rpm up until the distributor stopped advancing.
    Choking my ....... beerjet's Avatar
    Rancho Cucamonga
    Hmmm........
    Stand behind him fockin it up There is a line there IMO but I would say , no .
    New Port Richey, FL
    lol did'nt say it was me i have this friend lol
    No I did'nt sell the engine to him but to someone else. And I did explain to set the timing at 34 when it had stopped advancing. So the engine owner got the info 2nd hand. He had a friend with the proper timing light that was gonna check it for him. It did'nt get done before trying to set a new land speed record. And I did keep asking if they ever got the timing set correctly. That's how I knew to take my timing light with me to look them over.
    I'm just blowing off a little steam. He's pulling them anyway to paint them red. I told him I'd put a head gasket on it for him and not to worry.
    Hmmm........
    That sucks.... whoever set timing is responsible IMO
    #55
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    split it for a happy customer - you by the headgaskets and he can pay you to repair back to running condition -- YOU tune
    Hmmm........
    [/SIGPIC]
    Only perform the work after he has signed a statement that puts him at blame for the engine failure, otherwise, he may use this instance as proof that this problem (and any future problems with the engine) were your fault, since you opted to fix the problem free of charge.
    New Port Richey, FL
    Quote Originally Posted by Lucky View Post
    Yep there you go. I did show up for the maiden voyage to check it out. had a fuel leak, starter acting up (know why now) one drive wouldnt come out of reverse etc.etc. in too much of a hurry to get it to the water.
    Met them down the lake after he finally got it going. belt came off the power steering engine. starter finally gave out and they idled back on one engine.
    So I never got the chance to give them the once over.
    New Port Richey, FL
    It's a never ending story but when you reflect on the situation it is interesting how the turn of events come about.
    But, I'll fix it for him and help him tune it while insisting that he not run it until it gets final approval.
    Fresyes
    I was wondering how the starter could even turn that thing over..Guess it died tryin'.. None to subtle hint, right there.. Wouldn't it be backfiring through the carbs something nasty??
    Is it just me or are toilet seats getting smaller?
    Rancho Cucamonga
    Your the man .
    New Port Richey, FL
    Quote Originally Posted by rightytighty View Post
    I kind of kept my distance while he thrashed on it.
    They popped off easily and the starter sounded out of adjustment more than fighting the engine. But you would wonder.
    It is what it is Outdrive1's Avatar
    It's not uncommon to lock the distributer out on a blower motor and run what ever your advance is all the time. We also run our modified car with an alcohol motor locked out, and it has a lot of compression.
    Hey stalker, don't go away mad, just go away.
    Fresyes
    Quote Originally Posted by Outdrive1 View Post
    But with 60 degrees of advance, wouln't it be firing so early, it'd be poppin' through the carbs??
