How not to build an engine.
Results 1 to 14 of 76
    Cantard 71hallett's Avatar
    snow bank
    Default How not to build an engine.
    Cant wait on gn7 or steelcomp any longer and since I actualy work Here is what I found today. Pulled the motor this morning...... had lunch then started the tear down.
    This would be how you dont install a stud girdle.
Name:	how not to build a bbc 004.jpg
    snow bank
    This is what solid roller lifters dont look like. This is however what they look like when the lobes are playing musical lifters.
Name:	how not to build a bbc 008.jpg
    snow bank
    I found the guy that would ping back to me when I would thump the bottom of the oil pan with my palm.
Name:	how not to build a bbc 010.jpg
    snow bank
    Gear drives belong in garbage cans.
Name:	how not to build a bbc 011.jpg
    snow bank
    Is there something missing near #1 cam bearing or did GM just put those 2 bolt holes there for fun?
Name:	how not to build a bbc 013.jpg
    Why did you pull it apart???
    #55
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    LMAO sounds like the people that tell me "it was running great when I took it apart" when I give them their estimate. You know what my next question is
    Senior Member superdave013's Avatar
    That style sure does. The ones with the idler attached to the cover are worthy. I never understood the idea of 2 idlers just flopping around is a good thing. Maybe I'm just not seeing it right.
    snow bank
    That doodad that holds the gears together fell on the floor when I pulled the cover. lol
    You should have heard the customer when I told him it was a 396 not a 427!!!!!!!!!!!!
    snow bank
    The cam sounded sooooo huge I had to take a look. lol
    No, GM didn't put them there for fun, but they were only used in some GM marine applications using 2 gear cam drives with reverse rotation cams. Never could understand why nobody ever made a hold/wear plate like Ford's have, so you did have to fight end play on a roller. It would require a different cam gear that was cut for the thickness of the plate, but they could have sold it as a kit. Chevy ended up using them as soon as the hyd roller became standard. Alot of the later block aren't tapped, some aren't even drilled, but the area has always been there.
    snow bank
    Going to pick up the parts tomorrow for it GN7...... I will post a pic of it.
    Quote Originally Posted by superdave013 View Post
    gear=bad, 3 gear=better 2gear=best I agree, I have never run one of these because the whole idea scares me
    snow bank
    Same here, I just cant picture in my head how all that clankin and chattering can be good for anything.
