Turbo rebuild?
Results 1 to 8 of 8
Turbo rebuild?
    Senior Member oldschool's Avatar
    Default Turbo rebuild?
    Anyone know what the price range would be to rebuild a couple turbos? These are Turbonetics with cast iron Gentry exhaust housings. I understand the cost will depend on the condition of the units, but I'm just looking for a ballpark idea of cost range. From best case to dooms day.
    Thanks.
    Call Carson Brummett on those.
    Thanks Barry, i will call. I had a local guy, does aviation turbo rebuilds, look at them. He gave me a price of $500/per unit to rebuild, but one turbo had major damage. That one is another $500 for new parts, wheels, shaft, bearings, seals and new housing. He said he will rebuild the other to match. So $1500 for 2 like new units, don't know if that's good, bad or in the middle.
    Quote Originally Posted by oldschool View Post
    Going direct to the source may not be the cheapest,, but I know you will get an honest answer. Not quite sure what is left that isn't new if you put all the listed parts in the one, sounds like a new cartridge.
    Placentia, CA
    Might want to give Turbonetics a call.
    steveo143 AKA DiMarco 21 II
    Well, I spoke with Mr. Brummett and looks like I'm in the ballpark.
    Ada, Michigan
    They are really not that complicated.
    A rebuild kit for a Borg Warner with a new bearing is around $ 90.
    A complete rebuilt cartridge is usually around $ 325.
    That's everything except for the turbine housing and the compressor cover.
    Do a google search to find a cartridge for your turbo or for $ 1,500.00 you should have 2 new ones.
    turbocharger t4 | eBay
    Sep 2008
    Rancho Cucamonger, CA
    i think rebuild kits might be about $15per and then you're gonna spend maybe 30mins apiece...
    edit:
    you'll need to balance the new parts on the damaged unit.
    but come-on people $500 per? 2 bearings, 2 seals and a nut? are you guys crazy?
