Router bit??
Results 1 to 14 of 35
Router bit??
    Default Router bit??
    Rumor has it you can trim alum. plate with a router and a carbide bit. Are these bit just wood bits/tips????? Or are they special made for metal bits? I'm tired of filing and am lookin to clean this up a little.
    Senior Member Hydroguy's Avatar
    Forget it. To make it come out nice you would have to make several jigs each one to remove a little more than before because you could only take off a small amount at a time.
    Well... I think I could clamp a straight edge for the router to follow on the side that's straight(that's the one I jigsawed), the bottom round hole is from the factory, ....I guess I'll have to file the sides. Thanks for the help.lol
    I have seen a guy (at a well known shop) do some nice work with a little router table.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I didnt use a router but thats what i did with a jig saw to cut straight lines. I trimed my motor plates to fit and they came out great. One thing i found, a continueis spray of wd40 makes the cut alot cleaner and makes the blades cut alot longer. I just bought a few cans and had a buddy sit there and spray the blade while i was cutting. i would assume it would help even if you where using a router.
    The carbide bits will work fine. If you take off just little at a time, you can use a straight edge like you said, or even make some patterns. A router spins a little on the fast side, so you need to be careful and not take too much at a time. WD works well and if you do a little experimenting, you should get the hang of it.
    Senior Member cave's Avatar
    Mesa, AZ
    Go for it. Trim it up with a jigsaw. Make a jig out of plywood to the shape you want to finish off the cut. Then final cut with a 2 flute carbide plunge bit following the jig. If you try to to do this freehand you will be sorry
    A 1/2" 2 flute plunge bit that's at least 2.5" long will work fine. If you want just want to clean up the edge on that circular area then use a dremel with the round mini drum attachment. A belt sander works great to clean up the flat edges.
    Good luck.
    Did you ever try to make the pump brace?
    Takin it home
    Thanks for the info. Are we talkin just a "wood" router bit? I'll have to go look, a flute plunge bit huh? Anyone have a pic of 1? If not I'll find one. My router does have different speeds, sounds like I may want to turn her down a little. Re the brace Cave, if I can't find any plate cheaper than what I was quoted, I'll just buy 1 from Duane. Re the hole it's about the right size I'm just lookin to de-uglify it a little.lol
    try an aluminum coarse tooth burr grinder also some call them christmas trees. these in an air tool will cut the crap out of the aluminum. the regular burrs will gum up if not continually lubed, but the alum burr will remore a lot of stock, a lot slower but i have used them in a drill for small fillet work. also if space permits you might try a course wood rasp similar to a bondo rasp it will also shave the aluminum very fast. had a set of mounts plasma cut at a metal shop and they looked like a dog ate them out. took the rasp a filed them down pretty easily.
    Atlantic Beach, FL
    One of the machinists that frequents the boards strongly advised me to use a table mounted router only. Seems to make sense.
    Silverdale, Washington
    Aw crap. I forgot to send you a picture! Yep, a straight carbide bit, some WD40 and a straightedge works really well.
    Also, I'll snap a pick of the roundoff bit I used that gives a really nice rounded edge as well.
    Piece of cake.
    Cool, thanks for the help guys.
    I've found Bees-wax (McFadden-Dale sells it) to work better than WD-40. Lasts longer and doesn't require a 2nd person.
    If it were me, I'd make a wood (MDF) copy of the plate you have now, using a flush cut bit and some double sided tape. Then modify the wood to be exactly what you want (sands easier, and is 5 bucks if you screw it up vs 75), and when you are happy, use the same technique to modify the aluminum.
    It's actually pretty easy, just do use a router table and dont be in a rush.
    Oh yeah, and wear long sleeves, eye and ear protection, The bits of metal are F-ing hot!!!
    High speed aluminum machining, CRISCO yes! CRISCO the white thick stuff. (not the oil) Use a brush and watch out for 'spray' when hot.
