Difference between a Holley blue & black fuel pump?
Results 1 to 14 of 22
    Derby, Kansas
    Question Difference between a Holley blue & black fuel pump?
    Hi guys anybody out there know the differences between a Holley blue fuel pump and the black? Basically my old Holley blue will no longer keep up with my fuel requirements at WOT so I was wondering if I could modify it like the "black" first or if I just need to look into a bigger fuel pump. From the pictures the two pumps look the same externally but I have never seen the inside of the "black".
    Thanks,
    Loren
    The Black is a 145gpm. I got your PM.
    Derby, Kansas
    Thanks and I replied back.
    After brain storming with another racer here at work I'm wondering if my electric motor is worn out. The pump is old and has been used double duty skiing, tubing, crusing and racing for more years than I want to admit publicly.
    El Cajon , Ca
    The holley black is also set up for alcohol , The blue is not.
    my uncle has a slightly used mechanical 170gph holley pump that kept up with his blown 540 , twin dominators he's selling, no regulator needed. it flows great, no wires it has less than 3hrs on it, we've gotta run a belt driven deal on the new set-up to keep up with fuel demand.
    Derby, Kansas
    Thanks but I do like the electric after running it for so long.
    yeah, i remember thinking that myself till i saw the flow map on a holley black electric pump at wot, the mechanical 170gph holley doubles the flow to the carb/s compared to the holley black don't believe advertising, it'll cost ya a piston
    WHY I have never worn out the electric motor on one
    Derby, Kansas
    I find that hard to believe if you run them, even the ones in factory cars go out after so long.
    Derby, Kansas
    This is just a NA tunnel rammed 467 that runs double duty. No nitrous so I think it will be fine.
    Thanks,
    Loren
    This Holley Black flows 120 gph at 9 psi. 120 gal x 6 lbs per gal = 730 lbs
    730 lbs @ .5 lbs fuel per hr per hp would feed 1,400hp. I wouldn't try it but that's the math. This pump has 3/8" connections it should be able to feed 700 hp with out much of a problem but it depends on the fuel lines, fuel filter and regulator and pick-up tube.
    This Holley HP -150 flows 140 gph at 16 psi. That's enough fuel to feed 1,680 hp. Once again, I wouldn't try it but that's the math at .5 lbs fuel per hr per hp. This pump has 1/2" connections. It shouldn't have much of a problem feeding nearly 1,000 hp depending on fuel lines, filter, fuel pick-up tube and regulator
    The HP-150 feeds the 565 no problem (935 hp) with -8 lines from the tank to the regulator.
    I think the HP-150 cost's about $ 55.00 more.
    Sleeper CP
    Big Inch Ford Lover
    I ran the black pump on my 467 with no issues whatsoever. Yes, a fuel pump can wear out...I just replaced one for that very problem. It may not "sound" like it's worn out, but put it on a scope and see what the waves look like. It's easy enough to replace the blue with the black...same for same, no hassles, and plenty of pump.
    KISS
    are you comparing an oem mech with a claly smith, edelbrock, or holley six valve pump? I didn't compare the black Holley to the POS O.E.M. pump that took a shit on my EFI Mustang. They all take a shit eventually, other wise there would be no reason for parts houses, and we would all just go to salage yards for the unbreakable OEM crap(oh shit, I just admitted I drive a Ford in front of Steel, AGAIN)
    Cantard 71hallett's Avatar
    snow bank
    ohhh man.
