4800 hp !!!
Results 1 to 14 of 14
4800 hp !!!
    Ada, Michigan
    Default 4800 hp !!!
    Dayum, they made their own OHC cylinder head too !!
    http://www.yellowbullet.com/forum/sh...ad.php?t=94902
    LOL...I like the aluminum plate "scatter shield" along side the block...
    Ada, Michigan
    Looks like they started out with a semi tractor diesel engine block.
    I have to hand it to the tractor pullers and their innovations.
    When it gets to where you have to fabricate it yourself and you can't just buy it off the shelf already done it's a whole different game.
    we're gonna steal your header design soon because we're shit for fabricating i told hass to let me know a few wks before he bolts em on so we can build our set right next to em
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    LOL.....more like a scatter deflector!!!
    What is that thing, gas or diesel?????
    It has what looks like a dizzy at the rear but I kinda think and would bet it's diesel????? But the black rubber lines going into the head look line port nozzle lines? Alcohol?????
    Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
    Quote Originally Posted by Jim W View Post
    Jim
    its got plug wires, gotta be gas
    Some guys never learn. bocco's Avatar
    Livermore, CA
    The link in the first post explains it. Diesel converted to blown alchohol.
    Ada, Michigan
    Follow the yellow bullet link on the first page and it tells a little about it.
    It runs on alcohol and it's a 600 ci 6 banger.
    Most of those guys run the turbos in series and each additional turbo adds 40+ psi. I don't think longevity is a factor.
    The last line about sums it up.
    Tri-Cities, TN
    In the 80's we did the valve jobs and other work on 2 of these tractors since then I have done the camshaft of one of them. The one was an Oliver 88 that a GM engineer had done one hell of a job on in design work with a billet aluminum solid head. It was the mild one at only 80 pounds of boost. The second was an Allis Chambers 426 CID 6 cylinder, it was the "hot" one with a 3 stage turbo system and 140#'s of boost. Even with water injection the intake manifold temp would run in the 1200 degree range. Never dyno'd but was thought to put out somewhere around 2800HP on diesel...
    Spooled up both of these things would send you to hills to hide .. . .but they are cool...
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Can you even comprehend the noise!!!! OMG!!!
    That would actually be a very simple head to fabricate. With that much boost, port shape and effeciency is minimized, to say the least....
    Biggest challange would be keeping it together, and that's just a matter of mass!
    Tri-Cities, TN
    The oliver was an engineering masterpiece. The class stated you had to run the OEM block which was a 3 main block which he modified to use another OEM oliver crank that was a 7 main crank. All new mains were drilled and tapped into the OEM oiling system. It used BBC Pistons mounted on modifed production Oliver rods. It was pretty cool...
    Chris Straub
    Straub Technologies
    Tractor pulling is some straight up crazy stuff.
    I love watching it.
    Newton Ks.
    Yea it is, I love watching it too.
    H.L. Mencken
