anyone build an intercooler for top of carburetor
Results 1 to 14 of 19
    Senior Member badbug3's Avatar
    Default anyone build an intercooler for top of carburetor
    building a twin turbo bbc with the race aero exhaust manifolds and it sure would be nice to have an intercooler to go right on top of the b low thru carburetor.
    Quote Originally Posted by badbug3 View Post
    why not just use a water/alcohal injection set up. I made one, as well as an using an intercooler. I have a spray bar w/ 2 .025 holes, one over each carb. It is a boost activated resorvoir from manifold pressure w/ a check valve. No boost, no pressure. I am in it about, $200 in material and polishing. about 75% as good, 5-10% of the cost. Steve
    banks made what you're looking for, but i'm not sure they did it in the bigger horsepower ranges. why not just by a nice ev bonnet and a 2000hp air to water intercooler offa ebay for 159 bucks intake air temp would be crazy low letting you dump a buttload of boost on pump gas. be cheaper than finding a banks set-up like you're wanting. ev hat will cost ya 150, intercooler from ebay another 159.00, so less than 350 and it'd make BIG hp, with less i.c. pressure drop. we're doin a twin 496 with twin 2000hp i.c.'s then y-ing into the bonnet.
    Senior Member The Violater's Avatar
    Anyone make a cheap cooler for the air intake of a blown motor ??????????
    Cantard 71hallett's Avatar
    snow bank
    Quote Originally Posted by The Violater View Post
    Window washer fluid and a little pump.
    Senior Member cave's Avatar
    Mesa, AZ
    Snow makes a kit. I may go this route too.
    Takin it home
    Default ???
    What is an EV bonnet?
    like the windshield washer fluid, thats what the water alcohal does. A check valve off the intake manifold, into a resorvoir, thru a spraybar over the carbs. no pumps, no electricity, no switches, etc.. when boost, and porportionally you get water alcohal. when vacum, nothing. have dynoed w/50 h.p gains, can run lots of boost on pump gas,etc.. I'll try to get some pics.
    I ran the last one on blown 491 bbc 6-71. Currently on 572 w/10-71 and an intercooler. I am mostly using this one as means to meter more fuelv in.
    Here is the link to Snow. They work pretty good. It is a chemical intercooler.
    http://www.snowperformance.net/
    Quote Originally Posted by Snowboat View Post
    carb bonnet for blow thru systems. the ev has a lil velocity stack built into the bonnet that corrects airflow as it hits the carb. motors making over 1000hp usually don't need anything more than a basic hat, but smaller hp motors need it to correct a/f ratio to the cylinders, spread the air mixutre better.
    Quote Originally Posted by jockocougar View Post
    Would nitrus plates work to spray alcohol?
    snow bank
    Hey!!!! dont be telling on me!! Its a primer pump to get it running.
    snow bank
    You can make a little spray bars that go in the "vacuum" ports on the top blower plate. The lines running to them would then be for "boost reference"
    I already bought 2 two inch spacer plates to go on top of my present carb mount plate so I can get the clearance for 50 cc pumps, so I would like to run a spray tube in the center of those like a nitrus plate. What do you think ? I've already decieded I'm staying with the inline single feed vacuum secondary carbs, they work great for long distance cruisability and get great fuel economy. I took 750 centers and put 650 bowls and transfer tubes on them with no metering blocks in the secondary's so I could run them inline. Total low budget set up with used junk. They work amazingly well ! Just trying to tweek them a little on the low budget backyard motif '...........
