SoCal Engine Machine shops
Results 1 to 14 of 24
    Senior Member lbhsbz's Avatar
    Long Beach
    Default SoCal Engine Machine shops
    I need a good one, that will do shit right the first time.
    Between my last 2 racecars and this boat, I've been through about 6 of the shops in the area...some respected, some not. Everyone has ended up screwing up royally on more than few occasions. The latest....
    Cut first core block .060" over when I gave them .030 pistons and asked for a .030" engine....
    They found me another virgin core, but it had a spun main bearing, so they sent it to get line bored (or honed...I dunno), and proceded to do their bore/hone and deck work after the mains were done.
    I started pre-assembling last night, and found my main oil clearances to be, front to back: 005, 002, 002, 000, 003 .. (the crank is new, and I measured it anyway...its perfect) which means the line boring sub fucked up, and my machine shop didn't check it when the block came back, so they referenced the rest of their operations off the screwed up crank centerline, which obviously yields an out of square deck and cylinders....not to mention, I asked to set the deck clearance to leave the pistons .005" in the hole (plenty of room to re-deck in the future if needed) and he left me with 000 deck clearance.
    Big blocks are heavy. I'm tired of loading it in and out of my truck all the time.
    Here's what I'm looking for in a machine shop:
    One that can do everything in house, no subbing out line boring or crank work. More people involved mean more chances to screw something up.
    One that understands why torque plates should be used and why mains should be torqued while machining the block.
    One that understands that different rings require different cylinder finishes
    One that listens to what I want and does what I want without telling me that the details I'm asking for are not needed. I'm the guy with the money, do what I want and I'll pay what you want.
    One that checks their work before delivering me back a finished product. I'm tired of loading this thing in and out of my truck.
    I want a shop that can make all the holes the same size and understands the idea of a right angle.
    I had great luck with machine shops when I was younger and didn't measure anything, but now that I'm considerably more detailed and don't trust anyone, every block goes back at least once, if it doesn't go directly in the scrap bin. The response seems to be "just let us build the engine and you won't have all these problems".....yeah right. The reason I choose to build my own is so I know that its right...and because I've lost faith in the local shops.
    So, anyone got a machine shop that has done good for them multiple times? I'm not looking for one time customer input here...sorry, just that it could be luck of the draw. I'm looking for repeated success stories, preferably in the LA area.
    Thanks.
    evans,EVANS,EVANSEVANS IF IT ISN'T BROKEN IN TWO, THEY CAN FIX IT
    Anza, CA - Lost Lake, CA
    Taylor Engine in Whittier(Jay Steel), Paul Pfaff in Htg Beach, Dougans Engine(Ray in Riverside), Vrbansic Bros(Ontario), and Contemporary Auto Machine in Htg Beach(Yo Shigamasa).
    Those are some I've used over the years with good results(so have others on the board). Depending on what you want done, they aren't going to be the cheapest, but the work will be realiable, and able to be counted on.
    There are other good ones around, I just haven't used them because I've always been satisfied with this bunch.
    Hope that helps.
    RR
    Long Beach
    thanks for the responses....
    Evans was recommended to me by a guy who used them once years ago, so they've got 2 votes, and they're close by. I'll go check out their shop and introduce myself next week.
    I'll keep the others on my list as well.
    thanks.
    Atlantic Beach, FL
    You might add JMS racing in El Monte. They do everything in house, and can build and dyno. GN to Baja 1000.
    Family business for 30 years.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I used Orange Engine Rebuild, They are in anaheim. They where recommended to me after i got screwed over by a small local machine shop. I've only built one engine, but i cant tell you that i would call and ask them kinds of things during the my build, basic things and jim was always nice and willing to help. I guess he's def of somthing in one ear though so you'll have to speak up Just my experience.
    bgman here on the boards recomended them to me.
    (714) 635-4030
    Senior Member 74 HOWARD 21RC's Avatar
    909 Alta Loma
    I use Yo at Contemporary Auto Machine.I have used Yo for years.Very satisfied with his work.Yo does all the work himself and goes over everything with you when you pick the parts up.Contemporary Auto Machine is in Huntington beach.
    Hey Tom, That would be Yo shigimasa at contemporary Machine and you will not find another machinist with more knowledge and care for the work that goes out of his shop than Yogi. Its not checked or double checked, its triple checked and okay"d by Yo himself before it hits the door!! For cyclider head work hunt down Juan Mendoza, also second to none!!!!!!!!!!! IMLAO M
    Senior Member superdave013's Avatar
    thanks.
    just don't be put off by the looks of the place. Gene is dead on everything he does.
    Man, I haven't been there in years and he was older then dirt then. Good to hear he's still at it.
    B1 Racing cs19's Avatar
    Pfaff and contemporary in HB do good block work and it wont have to go back.
    i agree with your statement about a shop doing what i (the customer) want. i recently wanted my cylinders finished with a certain finish and nothing else, this particular shop could not do what i wanted and proceded to tell me i dont need it and they do this and do that with blown alcohol blah blah. i dont care..this is what i want, yes or no.
    B1Racing.net
    Member bennyb's Avatar
    Mission viejo,ca
    I used PFAF and I believe you were one of the people that recommended them.
    They are great people
    Go on get your ass outa here
    Senior Member HKROB's Avatar
    [quote=VDRIVERACING;458899]You might add JMS racing in El Monte. They do everything in house, and can build and dyno. GN to Baja 1000.
    Family business for 30 years.[/qr
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    As stated earlier, Taylor Engines(Jay Steele)
    Thumbs up
    Evans is the guy to use. Paul Pfaff gave Evans the nick name of "Old Dead Nuts" because everything he did was dead nuts on! You just can't be in a hurry! Good Luck!
