crank trigger, p2
Results 1 to 14 of 23
crank trigger, p2
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default crank trigger, p2
    I noticed the crank trigger only has 4 magnets (least that i can see), how's it know when to fire the other 4 cyliders? The dist has 8 dilio's that fly by the pickup, but from what i can tell the crank trigger wheel only has 4.
    The cyl's only fire every 90 degrees...(4 cyls per revolution) 4 cyls, 720 deg = 8 sparks. The dist/rotor (and cam) spins at half crank speed.
    Ah grasshopper, does the crankshaft not rotate twice for each rotation of the camshaft(which turns the distributor)???
    Boy are you guy's nice, wait til Chet sees that.
    I guess you have never been 180* out with a distributor ?
    Sleeper CP
    LOL good one
    #55
    San Clemente, Ca
    lol, i knew that, was just making sure you guys did too
    Makes sense now, when looking at the two i for some reason was thinking both spun at the same speed. Thanks, -1 point for me
    Cantard 71hallett's Avatar
    snow bank
    These guys are messin with ya...... the one with 4 tabs uses dual pickups.
    LMFAO
    #55
    San Clemente, Ca
    Sweet, so i can retard only half the motor!
    Oh my God!!! I'm LMAO!!!
    One more question like that Shaun, and you will forced to surrender your timing light and commit the first four pages of Ketterings S.A.E. papers to memory AND drive your boat full speed for ten minutes with the #1 spark lead clipped to your left ear lobe!
    Lurker
    NC
    What? I was going easy on him I was thinking the spark lead should be hook up somewhere else
    San Clemente, Ca
    LOL!
