Burst Panel
Results 1 to 8 of 8
Burst Panel
    Senior Member 1320h2o's Avatar
    Sparks nv.
    Default Burst Panel
    Ok i know this has been beat to death but my manifold doesnt have one and im gunna put one in! can any one help me on the position on the manifold seems like the way my manifold is only part of the burst plate will be open?? Am i crazy??? Am i not seeing something or what?
    Senior Member PE 316's Avatar
    Livermore, CA
    MOST Chevy manifolds get machined on the "FRONT" (timing cover) end of the manifold. There should be a large enough area toward the center of the runners for cylinders# 1 & 2. Buy a kit and take it to your local machine shop and have them cut the "window" in the manifold then drill and tap the holes for the mounting bolts (studs). Or you can send your manifold to one of the blower manufacturers (The Blower Shop, Hampton, Littlefield, etc..) and they can do it all for you.
    Sparks nv.
    Quote Originally Posted by PE 316 View Post
    I understand that much and i can do the machine work and i can buy the kit but do i need to machine it to the total opening of the panel a little smaller or????
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    The burst hole is designed to evacuate as much of the explosion from the upper end of your engine. The opening in the bust panel frame should be matched.
    They work fine when they are installed and will save you the collateral damage if used.
    So Cal
    Steve ... on some manifolds, the panel is larger than the area available to machine. Sometimes the floor of the intake covers some of the opening.
    kind of like this:
    Thumbs up Burst Panel
    Quote Originally Posted by 1320h2o View Post
    Its OK if it is a little smaller. It is much better to have it a little smaller than not at all!
    Gardena, CA
    BD
    You have to work with the manifold like brian points out.
    The object is to give the explosion somewhere to go very quick before it turns into the engine.
    Can cause much damage!
    So Cal
    Quote Originally Posted by willis View Post
    lol
    Willis and I have experience on this one ... people can say whatever they want, but one thing Willis and I know we can do really well is blow up motors
    When we do it, we do it right!
