Rejetting for more boost
Results 1 to 14 of 14
    Default Rejetting for more boost
    I'm upping my boost from 10% to 17%. Do I have to rejet the carbs [850 holleys]? Pat
    Kingman/Golden Vly, Az
    u dont mention the sz of the blower?...anyways...there was a thread on here about the same subject & i think the 850's power valves were blocked off & the jets upped to 86-88 squared ...i would start around that point!
    FastRat
    Blower is 6-71, no power valves, jetted at 82 primaries, 83 secondaries now. Pat
    pat, on my blown 475(9 to 1 compression) runnin a 6-71 19% i ran 86 squared, no pv's in the rear, 6.5's in frt.. plugs were purdyyyyy
    Ada, Michigan
    Question
    What does the O2 sensor read ?
    Hondo Jet blown540's Avatar
    Holland, Mi
    LoL, seriously though I'm looking for a good price point wide band, my lightning headers allready have bungholes. What's a good unit for spot checking/tuning?
    ptz
    ptz is offline
    so ca
    Wink
    Quote Originally Posted by blown540 View Post
    fast makes a nice one wide band style for around 5 bills.. might check ebay.
    you could use an egt from autometer for around 130 bills...
    they also do an afr with leds...for a few more skins.
    Thanks I'll take some jets with me. Pat
    Ada, Michigan
    The Innovate Motorsports unit is one of the most popular. I've had mine in the boat for 6 seasons now. It has built in datalogging and more features than you could ever use.
    IMO the days of making a guess at A/F mixtures are long past.
    Avondale,AZ.
    Rejetting should only be required if the carbs are at pretty much the top end of their airflow range, yours shouldn't be. If you have a too rich midrange cruise to get the top end right, add replaceable highspeed air bleeds and go about .004 smaller for starters. Otherwise the carbs will be mostly self compensating. Keep a good eye on your fuel pressure whenever you up the boost. TIMINATOR
    Holland, Mi
    Good info, thanks guys
    sacramento
    once it's too fat, you'll know for sure wich way to go
    Just went through this on the dyno yesterday. If the jetting is correct now, upping the boost that much won't change it. The carbs only react to the amount of air passing through them as they provide a ratio of air and fuel. Once that ratio is correct, the amount of air passing through the carb won't change that ratio.
    Senior Member 500BBC's Avatar
    CIUDAD MEXICO NORTE
    What kind of headers? You don't mean the water jacket bungs do you?
