Fuel Rail
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 43
Fuel Rail
    Senior Member The Violater's Avatar
    Default Fuel Rail
    Anyone make a fuel rail that mounts to the blower studs for 2 single feed carbs with the ability to put a bypass regulator on the end that I can just buy ?
    Cantard 71hallett's Avatar
    snow bank
    Quote Originally Posted by The Violater View Post
    I have been thinking about making one. How/what did you have in mind? Maybe we could get together on this?
    A couple of months ago, I asked about a by - pass regulater and some of the members posted some pic's of some really nice homemade rails with the regulater mounted right on the front of the rail, fuel inlet at rear made out of 1 1 1/4 or possibly 1 1/2 in hexagon pipe with a flat plate welded on the bottom that bolted right to the blower studs......... really sweet set up............ everybody says just get some stock, weld up the ends and drill and tap the fittings ! Not that easy for me, the blower stud patterns are all the same, I would just as soon buy one. Maybe they will catch this and post some pic's again ?
    snow bank
    If someone posts a pic of what you want I will make us a set. I think I know what your talking about but not 100% sure. Pics are worth 1000 words in this one.
    The Great Humongous P-Money's Avatar
    South Central WI
    I could use another one too for my NA deal....HINT HINT
    Quote Originally Posted by P-Money View Post
    There it is !!! Small world, I could't remember who posted the last time !!! Ironic that you just sold the Hondo to Hallett !!!! That's the unit, It will fit perfectly on my set up !!!! Maybe you can give all the dimensions to Hallet ?????? Please Santa !!!!
    snow bank
    This is something I have been thinking about as you can see. I started this but havent finished it yet. With your pic its a help. I will bring my blower home and get these done. How would you like the n/a one? 2 ports on top and a capped end? I have an intake I can use to mock it up.
Name:	hondo resto.jpg
    The only thing wrong with that picture is, I'm pretty sure you have your motor bolted in backwards !!!!!!! LOL !!
    snow bank
    I guess I will also need to know what size fittings your going to need/use.
    2 ports on top, fuel inlet at 1 end and by - pass regulater at the other end with return to a canister fuel filter. pm me your address, I'll send you the crude copper one I brazed together and ran last year, it has the dimensions, it's crude but it worked..........
    snow bank
    Will do.
    South Central WI
    This is the current NA deal I threw together to get the v-drive going:
    1/2 NPT on the ends and two coming out the top seems to work the best for my applications. Then you can play with the fuel lines from -6 to -10.
    snow bank
    Ok I will make one up for you.
    South Central WI
    Quit making shit for people and get back to work on the Hondo....just kidding...thanks bro. I'll take some measurements in the morning and shoot you a PM. And I'll get that damn plate in the mail Monday.
