Cams and water?
Results 1 to 14 of 32
Cams and water?
    Southwest corner AR
    Default Cams and water?
    What is the safest cam duration to run with injected headers? Large duration or small? WT
    WT
    WFL Crew!!!
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    The less cam duration the better, if trying to avoid reversion (water in oil)
    I think overlap and lsa have more/as much, to do with it. What cam are you lookin at???
    Do a search for cam duration, 71 hallett started a thread with alot of good info, I'd post a link but I'm too stupid.
    Southwest corner AR
    [email protected] .050 intake 240 exhaust 252
    lobe lift .3780 .3600
    Sep. 113.
    Dur. @ .006 .297 .317
    Gross valve lift .643 .612
    Degree intake lobe to 108
    WT
    WFL Crew!!!
    cfm
    cfm is offline
    Now there's a funky cam.
    Do you have the option of running the headers dry at idle and add water at a higher rpm ?
    Can you give us engine specs along with header specs (primary ID, length, collector ID and length)
    Hondo Jet blown540's Avatar
    Holland, Mi
    No need to mess with the intake side just get the exhaust closed by 10 deg ATDC
    Tri-Cities, TN
    Sep. 113.
    Coby,
    How was the powerband on the engine?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    cfm
    cfm is offline
    You are obviously concerned about water reversion since this is the second thread you started on this subject. 1st is located here:
    http://www.performanceboats.com//sho...712#post479712
    There, you mentioned using exhaust manifolds.
    I have questions about this cam since you are so concerned about reversion #1, and #2 it just doesn't add up any which way I put a scenario to it:
    1) What where the particulars and concerns when you bought / had this made ?
    2) What was the reasoning behind grinding the cam with the specs it has ?I still have not seen nor been answered on the rest of this engine's build. I've just seen exhaust and cam info.
    I am not the only asking as to why the cam is the way it is ?
    Sep. 113.
    I don't believe you are going to get away with this cam with headers that inject the water right under the port. How old id this cam? Seems like a lot of ad (.006")duration for only 252 @ .050
    Some of the things that raise my eyebrow:
    -Why the 113°LSA ? To cut down on overlap ? Still, the overlap is huge for what the cam is vs what it could be with same .050" .
    -This cam has 81° of overlap at .006" seat. That's big folks - and remember it has 113 LSA (ie:wide) and 240°/252° at .050.
    -The intensity is very large at 65°.
    -The i/e split is 20° at seat.
    - 317° at .006" to only raise the valve .612" with a 1.7 rocker.
    You're obviously in the wrong business. You should be designing cams.
    Or reading people's fortunes.
    I could be wrong, but the last time I saw numbers like that were on a old school GM hipo "offroad" cam. Really lazy lifter intensity and wide LSA. Some of those old GM cams had some insane adv. numbers that made the cam look way "bigger" than it really was. .006 lifter rise isn't enough to take up the lash, and they would seem to stay there for 10* to 12* before lifting anymore. Exactly the reason I pay no attention to adv numbers or even .050 for that matter. Tell me what its doing between .050 and .200,and .300 etc. Bet if you cam doctor that thing it's not what it appears to be.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    i dont know if this is the cam that chris ground for colbys motor or notbut if it is im sure there is a reason
    as far as water they make cut-off switches that with a flip of a switch no more waterif you are using injected headers.
    i have one so does all of my peeps i run with,moroso makes them and they are 100 bucks wire it up flip a toggle bamm!!!!!water, no water.
    i always cut my water off anything below 2500 rpm not that hard to remember when it comes to the money you have in a mill.good luck colby and may next season be better for ya!!!!
    cfm
    cfm is offline
    Thanks for your factual input Steel. I'm sure you'd take your comments well if directed towards you. Guess it's only okay for you to dish it out though. An FYI here: I am 100% curious about why/how/etc these specs where used.
    Anyhow,
    Here are some further facts/specs with this cam. Anyone, Please feel free to discuss them.
    seat at.006"
    IVO 40.5° BTDC IVC 76.5° ABDC
    EVO 96.5° BBDC EVC 40.5° ATDC
    81° overlap (40.5° BTDC, 40.5° ATDC)
    at .050"
    IVO 12° BTDC IVC 48° ABDC
    EVO 64° BBDC EVC 8° ATDC
    Intake_: 297 at .006", 240 at .050", 160 at .200" ___lobe lift .378" (.643" valve)
    Exhaust: 317 at .006", 252 at .050", 165 at .200"___lobe lift .360" (.612" valve)
    In intensity: 57
    EX intensity: 65
    OEM cams are usualy around 65-75 Intensity
    Aftmkt usually 50°-55° or so.
    Comp's off the shelf Extreme Energy Marine cams have 54° intensity.
    One Extreme Energy (XE) has 44°. Others 50°. Gosh, the old 268H high energy cam has 50°.
    This is part of what begs me to ask these questions. Why would I want a lobe with 65° intensity when I can get one's with less and are proven to be stable?
    Edited: Made a typo. Why would we want to start the blowdown of the exhaust at 96.5 BBDC (83.5 ATDC) ? End of Edit.
    I think these are very fair questions and I would like someone to explain them to me. I am not asking for derogatory comments, especially without some good info or questions presented. Lets discuss this and see what comes about it.
    GN7 - I believe those GM cams seat where measured at .0015" and thus why the seat #'s look so dang big.
    The cam above is measured at todays normal .006" . Crane does do it at .004"
    Imagine the seat # if measured at crane's spec and then compare to a Crane ? That 317 would be around 327 or more? at .004".
    Let's not forget what reverts water. It is actually spent exhaust gases that are reverting back into the combustion chamber that is carrying the water back. The more exhaust gases being pulled back into the combustion chamber the less available room for fresh air/fuel. Call it an EGR valve. Might as well.
    How does anyone know anything about this cam without knowing anything about the heads?
    CFM...what are you getting at here? You're "criticizing" the cam (as you do every chance you get with Chris' grinds) but you're not saying what the negative effect might be with this cam, or how it could be better. I'm not going to pretend to understand why Chris does what he does, but suffice to say, whatever it is, it's successful. This build, from what I understand, is no exception.
    What would you do differently, and what would you expect to improve over what this grind shows? Have you seen the dyno sheets? Have you seen the power curve?
    IMO your motives are transparent, and I don't think you really care about the cam, except to discredit Chris.
    There's your facts.
    Can't we all just get along. I only brought it up because I don't believe that cam is going to be wet header friendly. Perhaps with the right offshore type manifolds, but not an injected header. Cam appears at first glance to be very easy on the valve train.
