Nitrous plate question
Results 1 to 9 of 9
    460 is offline
    ATTA BOY 460's Avatar
    Default Nitrous plate question
    I have an adapter from my 4150 manifold to the 4500 dominator carb that im running. My question is, does the nitrous plate need to be directly below the carb or can i install it below the manifold and the spacer? If my thinking is correct, it shouldnt matter because the same amount of fuel/nitrous is going to introudced into the engine so it shouldnt matter where its at?
    CarbGuy RumRunner's Avatar
    Lake Lanier
    There is a two fold scenario here:
    First the further away from the valve you inject your nitrous the Harder it's going to hit, and shock your system.
    Second is if you're running a 4150 to 4500 adapter having spray bars at the bottom will have them in the way and can cut off some of your air flow. It's really a double edged sword.
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    run a 100 shot below the carb and a 200 shot between the adapter and manifold
    Bouncing off rocks TryMe's Avatar
    Sep 2008
    St Louis
    would you be interested in trading ayour 4150 for a 4500 spray plate?
    460 is offline
    Quote Originally Posted by TryMe View Post
    U bet. Check ur pms
    Lake Lanier
    Now be careful using a 4500 plate on top of your adapter the spray pattern may not be right.
    If it were me I'd flow test the plate on top of the adapter on top of the intake.
    Using CO2 (instead of N2O), and Safety Clean (Instead of gas) will give you a safer and cheaper way to flow test.
    Quote Originally Posted by RumRunner View Post
    x2 not a good idea to adapt up to a plate size. fositty, if your intake is 4150, run a 4150 plate kit. if you put a 4500 plate on there, some of the bars will get blocked by the adapter plate.
    cfm
    cfm is offline
    If you don't have a way to check as Rumrunner suggests, I'd use the 4150 plate under the dom-4150 adapter. You can make up for the very slight loss in airflow with more nitrous.
    Member Strip Poker 388's Avatar
    Ms
    I have a 4150 plate for sale,I think it needs a new spray bar?
    Rob
Name:	Parts for sale 12-04-06 020 (Medium).jpg
