blocks
Results 1 to 14 of 62
blocks
    Senior Member cheyenne580's Avatar
    Default blocks
    What's the pro's and con's on aluim.{SP} blocks over cast iron block's besides the weight difference?
    Jim S
    con--less horse power, expensive
    pro--repairable, available in wide choice of deck heights and and bore centers
    X2, but it seems that in a lightweight drag boat, the weight savings may be more significant then the HP loss.
    Hey GN...is that nail gun CA legal?
    Ada, Michigan
    I've heard the HP disadvantage point before.
    Does anyone have any data on how much of a % factor that would actually
    be ?
    Hey GN..is that nail gun CA legal?
    That's pending, but you just Arnold has one But then again, he has Hummers you and I aren't allowed to have
    That's pending, but you just Arnold has one But then again, he gets Hummers you and I aren't allowed to get
    You mean like from Maria?
    Precision Craft Marine
    Napa, Ca
    We have always had a better handling, quicker accelerating boat with an aluminum block. Remember that drag boats do not ever have enough heat in the motors when we actually run the boat. Even with our totally enclosed cooling system, the difference between the iron block and the aluminum block is not much, but the extra weight is huge.
    Kent, WA
    I personally used a Bowtie block for a ProStock engine. 500 inch Pontiac Kinsler injector. All I changed was the block to a Merlin-Lite. Same "everything" except the rings were new. Same brand and style rings, just new. Same guy doing the machine work too. + 38 hp on the same dyno !!!
    Gordy told me the same story, that I'd lose power ! I call BS !
    waterloo
    I am pretty sure new rings cannot make a difference. Hell, almost no reason to ever replace them anyway.
    Wags
    Couple of questions. Do you think an aluminum block can hold it's shape as well as an iron block? Do you think there's a reason NHRA Pro Stock engine builders will sacrafice more weight in an already iron block, because it'll make more power than something lighter?
    This is an old debate, and it'll go on forever. Your example is more the exception than the rule, and I'd venture a guess that something changed during the rebuild, because while in some cases it may be a wash, there's no way an aluminum block is going to make 38 more HP on it's own, over a good iron block.
    JMO.
    Ada, Michigan
    There's some solid results. Now that's settled.
    Whenever I heard the old story about aluminum blocks not making the same HP as cast iron it was always from someone who didn't have one.
    I also heard that my aluminum block would be corroded down to dust after using it in a boat. I've got 9 seasons on my Arias aluminum block and it's still in great shape.
    LOL...you go, unchained.
    I don't have an alligator, but I know not to stick my hand in one's mouth.
    Oh HERE WE GO AGAIN.......................
