Blower carbs
Results 1 to 14 of 19
Blower carbs
    Senior Member Hallett's Avatar
    Lakehavasu az
    Default Blower carbs
    Has anyone ever used allstate carburetor on a blower motor looks like they have some nice crabs for
    a decent price. any info would be appreciated.
    Co-Founder of SHB MarKist's Avatar
    yeah there nice and shinny
    Markist
    "Life is SO much better now......
    Senior Member smitt19's Avatar
    carmichael, ca
    Default blower carb
    Do they make a boost reference deal? I had a stock set of dominators running on 1000 hp set up and they didn't work near as well as after I had the carb shop modifiy them to a boost referenced set up,
    You'll get as many arguements for as against blower-purpose built carbs. I've heard that if you're pulling vacuum at WOT then you probably need referenced carbs, if not then you don't.
    Lakehavasu az
    Yes they do boost reference. i want to run the 4150 style carbs if i can
    run the 950's that would be great i don't want to change my air cleaner
    i would rather not run dominators. thanks for your input.
    spokane, WA
    I can get you in contact with C&S and they can built you a cumstom set of 4150 style carbs to your specs.!!!
    Let me know if I can help!
    tarvis
    Senior Member 76schiada's Avatar
    I have quick fuel carbs on mine, Good pricing and haved worked good.http://www.quickfueltechnology.com/
    Quote Originally Posted by Hallett View Post
    i bought 1 of their blinged out 1050's and when it got here, i took it apart. it had some race fuel in the pumps and some still in the bowls, you can tell it'd been ran, they run and flow they're carbs before they leave the building. haven't ran it yet but the work looks nice, carb is nice lookin(all shiney and shit) and so far i'm happy with my purchase, but still gotta run it the guy called me 2 or 3 times to ask questions about my set-up and how i was gonna use the boat, said he's got the air bleeds close enough where i shouldn't need to jack with em(i don't know squat about dominators other than jetting, pumps/cams, nozzles).
    i've seen a new dominator from holley and for 20-30bucks more, the all state is at least tuned close to your needs by pros, unlike a off the shelf carb, sure looks nicer too
    Lakehavasu az
    Thanks IMPATIENT 1 for the info i have talked to the them seem to
    talk the talk. did you go with the dominators . are yours going on a blower motor. thanks for the info.
    i bought this 1 for a single n/a stroker i'm built over the winter. i liked the boost but it wasn't gonna win any 1000ft races, so i went back to big inch and a ton of no2
    MI
    Tuf-enuf marine did my Dominators. They were perfect right out of the box.
    Junior Member powercat's Avatar
    Claremore
    I bought a set of 750's for a blower application. Adertised as boost refrenced but when I tore them down I found out they wern't. I did the mod myself which was no problem. The carbs look good and seemed to be set up correctly (accept boost refrence). Have yet to run them.
    DJD
    DJD is offline
    6TH STREET MAFIA PRES. DJD's Avatar
    Closer to the river than you!
    I put a set on this motor when i built it for a buddy and they aer flawless and work perfect. They came waaaaaaaaay fat but after a couple pulls on the dyno we had them rite were we wanted them.
    Lakehavasu az
    Thanks for the info guys still checking into them.
