crower cam id
Results 1 to 7 of 7
crower cam id
    Default crower cam id
    hello,any one here have any old cam books for a bbc crower roller cam, only marks on cam is x9423
    tried crower told me cam is to old, for the books, if not ill have to poke it in a block and hand spec it out ,just trying to go the easy way first ya know
    thanks up front.
    El Cajon, Ca.
    Quote Originally Posted by flat601 View Post
    thanks up front.
    Look on the back and there should be a work order number... starting with an "E"... unless it's really old... then it would start with a "D". Then call and talk to McLaughlin... he's an old timer and willing to LOOK THINGS UP. Reed Oliver used to be damn good down there but he retired this year.
    The Bostick®
    Default re/check
    cam gear end only crower and x9423 and rechecked timing gear end is blank
    I always get the odd ball #$$# guess it could be a custom grind, bought cheep for spare motor.
    Choking my ....... beerjet's Avatar
    Rancho Cucamonga
    So the back of the cam doesnt have anything . Thats the first time I've ever seen that .
    Chantilly Va.
    Default This is Interesting
    I recently acquired a camshaft from rich seibert,Its marked Crower ,Its a roller cam ...the only marking is on the rear of the camshaft.It is marked X1753...thats all. I was told it was a custom...thoughts???? flat 601 & myself have cams that only have markings on the rear...dist. drive gear end, of the cam...How do we ID these? six-o-nine...How do we get in touch with Mclaughlin???
    El Cajon, Ca.
    Quote Originally Posted by sunkisst View Post
    Call up the main number... you're gonna talk to Valerie at the front desk... ask to talk to mr mclaughlin... she'll forward you. Otherwise you just go through the automated directory thingy.
    The number is 619-661-6477
    do not recall if this is direct or what as I have several numbers since before they moved... oh 5 years ago and still haven't cleaned out my phone book.
    What is odd is that even custom grinds they "most of the time" still have a work order number stamped in the rear... E65062 for example... unless like I said it's some ancient 70's stuff... I have an old "Imperial Roller" roller cam from the late 70's that has only a U1135 number on it...
    The Bostick®
    Chantilly Va.
    Default six-oh nine
    Myself and flat thank you!!!!Gonna give a call in the AM...Thanks again,Jack...Happy New Year!!! EDIT....Hey six-oh-nine,I just called the no.you gave me.The same answering service chick that answers the online tech line,answered now.They are closed through New Years...Thanks for the "HOOKUP"...Jack
