Carb size question
Results 1 to 14 of 91
Carb size question
    Rancho Cordova. CA
    Default Carb size question
    Hey guys. I am kinda new here and have enjoyed and learned from a lot of posts here. I can see there is a lot of talented peeps here that build engines and entire boats. First I need to tell you guys about my engine combo and what it is in....It is a chevy 496. 10.2 to 1 comp. I am running 396 heads with the 1.88/2.19 valves 96cc chambers, flat top SRP forged pistons, Eagle "H" beam rods, Eagle steel crank, the cam is a hydrolic roller
    242-254 @ 50 .670 lift with 113 sep. and roller rockers on top. Exhaust is thru transom Bassett headers. I am running a Weiand tunnel ram with two holley 450's on it. It turns a berk JG with a Berk "A" , a stage 1 blue print with a stuffer (blue print was CP Performance) to 5200 rpm with a place diverter. It is a 1991 Carrera Eclipse 21 ft shallow "V". I have only had a gps read back when I had a tired 454 with the same pump combo and it spun 5000 rpm and that was 69 mph. I am guessing 72 ish with the 496. I can run a long time before I need fuel. A lot of peeps say I need to step up to bigger carbs. Let me say I am not looking to get some insane speed here. My deal is acceleration....quick and hard. Do you guys think bigger carbs are worth my time? I like to be pinned to the seat more than MPH. It throws you back pretty good as it is now. I would like to hear some thoughts on what you guys may think. Oh, This is just a lake and river boat. Thanks in advance!!! Mike
    With the combo you say you are running I would imagine that your'e plugs come out looking brand new!!! If you look at the plenunm and the feul you are toosing at the motor you are running then the carbs are great for a SMALL BLOCK. I would not run anything smaller than a pair of 750's on that set up. In a word yes you are way lean,Okay more than one word but If you think it tosses you back in the seat now then feed it and go change you're shorts and call back in the morning.
    Rancho Cordova. CA
    Hey Old Guy. Thanks for your response. I have been down the dragstrip here in Sacramento quite a few times with my pavement pounder. I don't mean ANY disrespect, but I can't see a 496 sucking down more than 900 cfm at 5200 rpm. I belive (imo) I will just burn more fuel with bigger carbs
    with little to no performance improvement. I do understand I may be wrong. All I ask is it to be explained to me. Thanks for any input!!
    Senior Member hotbo's Avatar
    lake Ouachita AR
    put a set of 600s on it and you will still conserve fuel and get better response in the mix.if you put 750s thats even better but i bet youll be happy with 600s.jets love more fuel and air and with those carbs in a 496 package you are chocking the stroker downsome will say even bigger but you do have a large boat and a nice looking boat by the way.good luck hope this helps.travis
    Tri-Cities, TN
    I think a set of 750's would be your best bet. The air speed that must be in the venturi has to be just insanely fast with the combo over 5000 rpm and those 450's which would lead me to believe your not getting good atomizing of fuel. You need to slow the air speed down with some 750's and I bet she'll pick up power everywhere.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    please explain how a a pair of 450s equates to the term "lean"
    The Man cordog009's Avatar
    East Texas
    How about a pair of 660cfm Holley 4160s like I have on mine? They are a compromise between the 600s and 750s.
    1984 Youngblood TX-19 SOLD
    and have all the drivabilty of a brick with a hole drilled in it.
    Newton Ks.
    I think if you want to burn more fuel and gain nothing noticable, bigger carbs are a perfect idea.
    Go much bigger than the 900CFM you are already trying to shove thru stock, closed-chamber heads, and you will only "negatively enhance" your driveability.
    I'm sure someone will sugggest twin Dominators tho.
    IMO you'd be better off with a better head, as far as "bang for buck" gains available.
    H.L. Mencken
    East Texas
    That's what I was thinking as well.
    First I would recomend a good 'ol vacuum gauge connected to the base plate. This will give you a good idea of how hard those little carbs are being sucked on at [email protected]. You probably have a 560hp combo there. Myself and many others have made over 640hp w/496 and a 800dp. I have worked with these 450s alot. They are a little lean out of the box for the combo I had run them on. A secondary metering plate change was all that was needed. Now there is a adj. plate available from Percy's I think. 750s would have the HP advantage on the big end. Fuel consumtion is a non issue at part throttle. It still takes, lets say 400cfm to cruise your boat, so total carb size doesnt matter at cruise. The bigger carbs just arent open as far.
    Senior Member CHEVY JET's Avatar
    St. Charles, IL
    THAT IS A REAL GOOD LOOKING BOAT!! I AGREE JETS DO LIKE FUEL, MY DAD HAD A 78 KONA 21' DAY. HE HAD A 950 HOLLY ON IT, TOOK IT OFF AND PUT A TUNNEL RAM ON IT WITH TWIN 600 AND GOT BETTER GAS MILAGE. MORE FUEL ISNT ALWAYS MORE FUEL CONSOMPTION. SOME TIMES IT TAKES MOER FUEL TO MAKE A SMALLER CARB WORK RIGHT. IMO
    lake Ouachita AR
    all of these good points.but the 450s are to smalltalk to chris straub thru pm he is a super guy and he can tell ya what he means by velocity and such.yes the 750s will be a good choice no matter the head combo.
    smokin so whats your excuse for the slowriderjust pokin hope all is well.\
    those damn cfm calculators are good for street srtip stuff imo jets are different remember this when thinking big end or low end hell there is no low end when you mash it if it turns 5200 rpm it turns it instantly
    Cas
    Cas is offline
    Angry American Cas's Avatar
    this is the carb Mike is running-
    Carburetor Flange: Square bore Choke: None Fuel: Gasoline Secondary Type: Mechanical New or Remanufactured: New Fuel Inlet: Single CFM: 450 Carburetor Finish: Dichromate Ford Kickdown: No Throttle Linkage Type: Universal Quantity: Sold individually. Notes: This has a mechanical secondary, but no secondary accelerator pump circuit. It is designed for a mulitiple carburetor application ONLY, it will not function properly on a single carburetor application.
    actually 2 of them.
