cam help
Results 1 to 12 of 12
cam help
    Senior Member eliminator's Avatar
    Roanoke VA
    Default cam help
    I need advice, 454 60 over 8.25 compression 871 moonyham . does this cam sound ok , advertized duration @ .050 235/245 lift .555/580 lobe center 112' this is hyd for 2500- 6500 rpm doug herbert brand going in a ski hydro .
    Spider Monkey Racing
    FRIENDS DONT LET FRIENDS DRIVE EGGBEATERS
    Hondo Jet blown540's Avatar
    Holland, Mi
    Wow, I'm by no means a cam expert but that cam seems really conservative for your application Are you sure you wouldn't be happier with somthing in the 260-270 range with .700+++ lift? What are your heads set up for? What fuel? I vote for bigger
    Roanoke VA
    thats the problem , I dont know what I need, this is my first go around with a blower engine, I am going to use the 781 heads .its all I have .This thing needs to be pump gas friendly and I am on a tight budget.
    Holland, Mi
    Ahh, the money thing......understood Seriously for 75 bucks you can't beat that cam! And you won't have to spend a bunch of $$ on the rest of the valvetrain. Maybe you'll even luck out and not have to buy new springs
    RLP
    RLP is offline
    I know they have a solid roller like 642 lift and a 244 @50 good cam
    sorry its 242 242 @ 50 CBH2 Herbert
    Senior Member cave's Avatar
    Mesa, AZ
    Dry or Wet headers?
    Takin it home
    Quote Originally Posted by eliminator View Post
    I don't know all the info that you gave Doug,Chet or Don Johanssen but they have more expierence in cam grinding than most will get in a life time!! If it is what they recommend then USE IT. I swear by herbert cams and will use nothing else! I built more than 1 468 bbc and will admit they were under 6-71 blower but Herbert recommended the cam and it was I used and never dissapointed! M
    Roanoke VA
    I will be running dry zoomies
    Atlantic Beach, FL
    You can stay conservative on the lift with a blower, say 650-ish, which will help you valve train live longer. You'll want a wide lobe separation, around 112-114.
    Comp Cams has a blower specific cam you might want to look at, and I have had good luck with Isky grinds. Call them and give them your specifics and they can guide you on the duration, but try to stay with the lift and lobe separation above.
    Smile
    That cam is conservitive, but will work. The problem is the other cam choices could have issues with stock length valves, causing coil bind. This is an area where it can be a can of worms waiting to be opened.
    I would like to see a little more duration on both sides like 248/252 or close to that. Water reversion is not an issue since you have dry zoomies.
    Just my 2 cents worth.
    Good Luck
    ptz
    ptz is offline
    so ca
    Red face
    high lift isn't as important as lca..
    blower makes over 100 ve..
    the trick is not blowing the fuel out the exhaust..
    most of the top fuel cars run .500 lift..
    something to think about..
    like it was said..
    chet knows more than most will ever know.
    he also pioneered some of the first rollers.
    they also grind for other manufacturers..
    something else to think about.
    they offer alot of bang for the buck.
    just my .02
    Roanoke VA
    Thanks for the input, I talked with the people at comp cams and for what I am trying to do they said the cl11-556-4 was the way to go , so we will see
