Crank Trigger Timing Graph
Results 1 to 14 of 16
    Atlantic Beach, FL
    Default Crank Trigger Timing Graph
    You might find this interesting.
    This is from the MSD website showing the timing variance comparing a crank trigger to the internal trigger on a MSD mag. I presume this supports what many have said about the superior accuracy of the crank trigger.
Name:	Timing Variance.jpg
    7* of swing... Yikes
    That make some expensive paperweights
    My brother and I always check the timing on the river at 4,000 rpm. When we put the trigger on the bonce dropped to next to nothing...rock steady compared to the bounce that used to be there.
    Crank Triggers, especially with Nos are the only way to go.
    Sleeper CP
    Big Inch Ford Lover
    Lurker
    NC
    That's the same thing I have been talking about in previous threads.
    Now picture each cylinder (that is just one or an average of all) moving around that much, but none doing the same thing at the same time!
    It's a mess when looking at all of them simultaneously throughout a dyno pull!
    Now imagine running at 850hp for hours at a time, with rules not allowing crank triggers!
    We have spent countless dollars trying to get distributor's to look like the crank trigger graph.
    It's not easy.....or inexpensive!
    Forgot to mension, that is only 3-4k rpm's. You should see what 6500-9500 looks like!!
    Nechako
    Question cam drive
    warp what does nascar have to run ? is there much to improve on in the distributor itself or is it mostly the " harmonic's " in the valvetrain that screws things up ? thanks for sharing your top shelf info !!! , mostly well beyond anything i'm going to do hope my punctuation is ok
    Ada, Michigan
    But that's just the tip of the iceberg when discussing negatives of the old school setups we all run.
    What about current loss through the rotor, current loss through the 30" long plug wires, .0021 sec coil charge/discharge time for one coil to fire 4 cylinders per revolution at 7000 rpm ?
    Lurker
    NC
    Quote Originally Posted by Canuc View Post
    We are only allowed hybrid types of the standard MSD or similar. And every time we breathe on them it has to be approved.
    We have learned a bunch in the last ten years or so (none I'm really allowed to speak of hear) but they are still terrible.
    Warp,
    Any stated reason as to why they won't allow crank triggers and roller cams. It seams like the cost of parts for both would be cheaper than making lessor parts better ?
    Those are just two rules that seam really dumb.
    Sleeper CP
    [email protected]
    Ohio
    And if you think about it, production cars don't use distributors and have roller cams. And they call them "stock cars". Hmmmmm
    Tim
    you left out EFI, traction control, ABS, alloy blocks and OHC
    [email protected]
    Ohio
    Some times they could really use the traction control button.LOL
    Tim
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    Tim
    You left out Onstar
    Sir, this is Shaquilla from Onstar. It appears you have been in a acciadent. Do you require assistance????
    Sir??? Sir???
    LOL, Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    When limited to a MSD or other mag pickup distributor by rules I'm sure there is a lot of top secret mods that can be done.
    Some not so top secret mods is to use the bendable reluctor. To try and tailor the ignition timing to each cylinder where you want it.
