Con rod ?
Results 1 to 9 of 9
Con rod ?
    El Cajon, CA.
    Default Con rod ?
    If a H beam rod is generally stronger than a I beam rod, why are most of the aluminum and titanium rods (that I have seen) a I beam rod?
    415 M3
    So Ca
    I beam rods
    I would double check on the information that says H beams are stronger than I beams. I'm not sure that's correct.
    I'm not sure of anything, though...
    Don't H beams create more windage ? or something like that. From the H-beam design I don't think an alumi H-beam would have much integrity would it ? Or it would be massive to have any strength.
    I think, I could be 180* out.
    Sleeper CP
    Sleeper CP
    At the cam?
    each design has it's positives and negatives. Each design is stronger in one direction, not as strong in the other. When you consider that a rod's major load is in tension, probably comes down to beam mass more the shape. Last time I looked, the bad boys of alumn fueler rods did not have any beam "design". Just a straight, solid beam.
    El Cajon, CA.
    Why does it seem like big HP engines run aluminum rods but they're not common on street/strip cars or most boats?
    Senior Member SkyHarborCowboy's Avatar
    Nov 2008
    Arizona
    I am guessing it has to do with the fatigue life of the metal. Since top fuel engines are torn down much more often then a typical street/strip car and the parts are replaced much more often it isnt an issue. In a street car I bet you would see a lot more failures from the same parts at half of the HP over the course of 100K with aluminum rods.
    Joe
    Thanks,
    Joe
    1988 Commander BBC454 Berkley JE-A with A-Impeller
    Blown Alki and Nitro engines use Alumi rods to absorb the shock to the crankshaft. A billet crank in a Nitro engine would snap about 10 feet off the line if it had steel or Ti rods.
    There was a thread two weeks ago about alumi rods in boats and cars. I'll see if I can find it. It has to do mostly with heat cycles and not knowing how stressed the alumi rods get, but heat really weakens them.
    Check out this thread:
    http://www.performanceboats.com//showthread.php?t=25812
    It started one direction and ended up going another, but good info in it.
    Sleeper CP
