555 BBC for the TR2
Results 1 to 14 of 16
555 BBC for the TR2
    Senior Member 78COLE's Avatar
    Greenville SC
    Default 555 BBC for the TR2
    Thought I'd post my engine config and dyno results from my 555 for reference. Dart Big M block 4.560 bore. Eagle 4.250" 4340 Crankshaft, Eagle H-beam 6.800 rods, JE domes. I dont remember part number but made a little over 14/1 with 118 chambers. Heads: Dart Pro 1 345, K-motion 1.625 doubles w/dampers, again dont remember part number. Around 300# seat with shims. Heads hand ported by Xsr Cylinder Head. Flow: 385/in 303/ex at .700. Cam by Jones Cam Designs in North Carolina L/C 112, Intake C/L 108, Exhaust C/L 116. Duration at seat 344/in, 348/ex, dur. @ .050 291/in 294/ex. Lift .771/in .770/ex. 1.7 Jesel shaft rockers. 4/7 swap cam. Peak torque 706.3 @ 5600. Peak HP 915 @ 7500. Was at 900HP @ 6900 and we spun it to 883HP @ 8200. Made 900HP to 7900 then fell off. Torque stayed high 600's until about 7000. This setup is topped by Dart tunnel with two 1150 Dominators. Msd ignition 7al-2. Intake also direct port 200hp nitrous(didnt dyno with N2O). Whew... long winded but didnt want two leave anything out. Let me know if I did.
    Wow, do you plan on spinning it to 8200 plus in the boat? All I can say is nice and lets see the boat.
    Member 76 BUBBLEDECK's Avatar
    Santa Rosa, CA
    Congrats on your build. Sounds like a pretty stout piece. Any pictures of the motor and or of the build, would love to see them if you have them
    Nick
    Sounds like a nice build. What valve train, and what oil pan if you don't mind saying?
    Sorry...just saw the Jessel rockers...
    So the real question is, did this build do what you wanted/expected it to do?
    Greenville SC
    Dont mind saying at all steel. Unfortunately the pan is regular sump Milodon V-drive piece. Did make custom pick-up though as we had problems with milodons piece from a previous build. Valve train: Comp pres. fed lifters, manley pushrods, jesel 1.7/1.7 pro shaft rockers, 1.625 springs... they are k-motion dont remember spec, good to .810 lift. Were recommended by Jones cams. 2.30/1.88 manley valves, titanium retainers. As far as did it do what i wanted?? I was a little disappointed on the torque numbers with that cubic inch but we'll see. The boat had a pump gas 496, dynoed 679HP @ 6800. Ran 103 on gps. Never got to a race for an e.t. Guess I wont know till first pass down track. Might can get idea from GPS run.
    H2O as far as turning 8200... I would like to be in the 7800 range but who knows at this point. Gonna be trial and error on gears and prop. Bad part is no close racing in South Carolina. At least one race will be test and tune. I'd like to be 9.0's on motor.
    I'll try and get some pics of motor up tonight
    Greenville SC
    Default motor pics
    Here are a few of the motor.... How bout the homemade run stand! H2O, just posted pics of the boat in V-drives. Appreciate the interest.
Name:	cam 1 002.jpg
ID:	29068   Click image for larger version.
Name:	cam 1 003.jpg
ID:	29069   Click image for larger version.
Name:	cam 1 004.jpg
    Nice...
    Good job
    Sleeper CP
    Derby, Kansas
    Sounds like that should certainly pick that TR2 up a little on the performance end.
    Greenville SC
    Default similar N/A combinations
    Just curious what anybody elses results were on similar N/A combinations. Also lookin at the dyno results, with the direct port 200 shot, what kind of realistic torque/horsepower increase should I look for?
    Quote Originally Posted by 78COLE View Post
    Not exactly similar but here are two you can look at:
    Cyclone:
    582", 13.7:1 compression, 1,041 @ 7,100 na, 1,284 @ 6,900 Nos
    http://www.performanceboats.com//showthread.php?t=20956
    Sleeper CP:
    565", 11.8:1 compression, 935 HP at 7,000 na, didn't run the Nos on the dyno.
    http://www.performanceboats.com//showthread.php?t=1874
    Sleeper CP
    Big Inch Ford Lover
    Mohave Valley/Quartzsite
    Nice piece!! Should definitely run well in a TR2.
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Greenville SC
    Appeciate it stix! I look forward to gettin after it the first time.
    Greenville SC
    Cyclone:
    Sleeper CP:
    Sleeper CP
    Big Inch Ford Lover
    Nice build there CP. Im sure that 565 has surprised some people on the lake.... or shut em up
    Thanks.....it's not your father's "Oldsmobile" that's for damn sure
    She holds her own for the most part
    Sleeper CP
    Big Inch Ford Lover
