bad msd????
Results 1 to 14 of 35
bad msd????
    "BOUGHT NOT BUILT" 2FORCEFULL's Avatar
    Default bad msd????
    what happens with a bad MSD???
    could it have a week spark??
    Senior Member 78COLE's Avatar
    Greenville SC
    My last motor a N/A pump gas 496 had a msd blaster 2 coil on it. Kept losin mph until i pulled motor. Tried on new high compression race gas motor, skipped like hell. Went to Msd Pro power coil... problem solved. So I guess weak spark is possible. Just my .02
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    a bad msd -- nawww
    [/SIGPIC]
    Tri-Cities, TN
    It's not uncommon these days. . .
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    The Earth
    Blog Entries
    24
    First thing to check is to make SURE you have a good SOLID GROUND and HOT source. They are very sensitive to these issues.
    I had a bad coil one time that gave me fits and smoked a box. Other that that I've had no issues. Lucky? perhaps.
    Ukiah,Ca
    YOu wish you where lucky .... Mr. Eagle eye
    [/SIGPIC]
    if the chip limits the rev, couldn't just that part go bad
    the very first thing I do when I think I have an ignition problem is pull the chip, and just leave it out. If this thing is missing badly, check ALLyour connections, especially the grounds! May even think about disconnecting the tach if it's electrical. If it's still banging, send the box in. Coils can go bad, but usually cause power and RPM drop, but not a bad miss. A bad miss in a MSD is usually a loose connection in the box.
    thanks,not miss'n every prop I try, the motor revs to 4800,from 62 -72 mph with the different props
    hallett 270 540 c.i.......
    I try'd a 27p four blade, gets right on plane ....4800 rpm
    i was wondering how do you know if the msd is bad
    didn''t know you could run without a chip in,.........
    Quote Originally Posted by 2FORCEFULL View Post
    Oh sure you can. Just ask any Nascar crew chief. Those drivers love pulling those things out
    I think you would notice if your bumping the chip, by vibration, and sound. Try the easy stuff first, saves on moneys.
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    I can't say what a bad coil will do but when i had my motor on the dyno I hooked up my old MSD, Did a couple of pulls and had stoped dead in it's tracks.
    Not sure if this helps or not.
    Greenville SC
    I feel pretty sure the chips go bad regularly. We had a boat this year at KDBA races that ran a 9.58 all out so we chipped it a lil to knock it down to ME(10.00). Every pass you could hear it hit the chip about 3/4 track. Guy made it to finals one of the races, with same chip in he broke out. Motor never hit the chip and all day had been running consitstant 10.0's. Happened at one other race with another chip. I know this isnt the best way to slow one down but it was pretty efective until then.
