BBC 454 Mag motor hp specs
Results 1 to 8 of 8
    Default BBC 454 Mag motor hp specs
    Trying to figure out a few specs on my motor. Its a BBC 454 gen 6 marine motor with the following specs
    plastic timing cover
    factory roller cam
    Rectangle port heads(they are the service replacement for the 990's)
    forged slugs
    7/16 rods
    steel crank
    4 bolt main
    no provision for mech fuel pump
    1 piece rear main seal
    Looking for...........
    compression specs
    factory hp specs
    factory cam specs
    any help would be greatly appreciated. Thanks Spitter
    Last edited by 396_Ways_To_Spit; 01-11-2009 at 05:29 PM. Reason: more info added.......
    G H E T T O F O E L I F E
    Here is some info that I found...................
    "There are three different types of marine 7.4L 454 cid engines. Some of the engines are interchangeable with only a few changes. NEW long block engines are available only for 1987 and up big block engines. If you are replacing a pre-1987 engine and you are looking for a direct replacement you will need to purchase a remanufactured long block"
    or
    392 Hp @5000 Rpm / 447 Lb-ft @ 4,000 Rpm
    This longblock comes with complete with cast aluminum valve covers, an 8 quart oil pan, composite timing cover, and harmonic balancer. However it does not include the intake manifold, water pump, or flywheel.
    I dont know for sure if its a MAG motor or not. Thats what Im trying to figure out.....
    try this
    http://www.cpperformance.com/detail.aspx?ID=3360
    oops look like you found it
    #55
    Silverdale, Washington
    Where the hell you been Mike? How's that new boat now that you've had a chance to run it out a bit?....john
    hey John Ive been godd, thanks for asking. The boat runs killer but plan on going to a bigger blower on my backup motor. Then I will be dropping in my nasty motor this year Hows everything been for you? Pm me so we can chat
    Mike
    El Monte
    Just for reference, if it was a Mercruiser 454 Mag. it was 8.6:1 comp and 385 hp. in the configuration from them. IE: MPI intake, their exhaust and tuning, etc.
    B & D Marine Performance
    El Monte, Ca.
    cfm
    cfm is offline
    There where two rollers used for Gen VI's . Depends on which 454 you got. Take a look here http://www.mercruiserparts.com/selec....asp?type_id=8 to look up engine and then click on 'cylinder block and camshaft' and get part #.
    Then use that part # to look at the following info from my notes:
    Merc Std BB Roller
    Merc# 431-850453T / GM#12552296
    .004” 280,299
    .006” 266*/284*
    .050” 204*/209*
    .200” 113*/114*
    Lift .480”/. 483”
    ICL 115.5*
    ECL 120.5
    LSA 118*
    Merc Mag Roller
    Merc# 431-850478 / GM#12551622
    .004 300*/ 300*
    .006 288*/288*
    .050” 225*/225*
    .200” 125*/125*
    Lift .483”/. 483”
    ICL 109*
    LSA 115.5*
    Ok, still trying to find out what I have. My blocks casting number is.....
    10237297
    any ideas????
