A different bearing question...
Results 1 to 8 of 8
    The Right Coast/SE-PA
    Question A different bearing question...
    Are the thin pencil tracks left by the dial bore guage harmless, can you safely burnish them away somehow?
    P bearings? would worry about it, unless your dial indicator has a chisel for a tip
    Default Thin coating
    I think what you're refering to is just the thin "break in coating" on the bearing. Some people actually remove it with scotchbrite. The bearing manufacturers tell you not to, it is there for a reason. The slight "pencil" lines you're seeing should be harmless, and will disappear in a few minutes of running. If, however, you get into the "shiny" stuff you might want to lightly rub them out with very fine steelwool / scotchbrite..........Set the spring load on the bore gage to a minimum at nominal size.......Ray
    LOUD BOATS SAVE LIVES
    My brother does not mind them, and runs them like that all the time. Never had problem one. I however, just can't stand the looks of that groove, so I polish them off with 2000 grit sand paper and then clean them real good before instalation.
    Quote Originally Posted by Wannabe View Post
    get yourself a different indicator tip or a lighter spring
    Question
    P or H...are you saying the P's 'would' be a problem if the bore gauge left some tracks?
    And If so, how should one deal with it?
    I realy wouldn't worry about it. I always clean my bearings before final assy...I used to use Scotchbrite until I found out it's impregnated with an abrasive that can get imbedded into the beairngs. Now I just use a terry shop towel and clean solvent and give them a good wipe, always in the direction of rotation (meaning not perpendicular to, or across the bearing.)
    No, I asked that because I couldn't imagine leave a "pencil" line on a "H" bearing that easily. Like Steelcomp said, a CLEAN shop rag and some solvent is the best way to clean up a bearing. I never did use the scotchbrite deal but I did use to use worn 1000 grit paper. Now its just a clean shop type rag and some solvent or WD-40
