Tach signal waveform shape???
Results 1 to 13 of 13
    Default Tach signal waveform shape???
    Our playback tach quit working before Phoenix and I'd like to confirm if its the tach or the interface module between the mag/tach. Obviously, the easiest thing would be to plug the tach directly into a car with a standard ignition. Unfortunately, I don't know anybody that has one.
    I have a function generator that can simulate various wave forms and am familiar with trigger thresholds. I'm guessing the signal is some type of TTL or similar square wave. So anybody give me an idea what the tach signal waveform shape looks like from a MSD or similar ignition? Hope its the interface module and not the tach....
    thx
    Hondo Jet blown540's Avatar
    Holland, Mi
    For testing purposes I would use a square wave, it's the ideal waveform for triggering digital electronics
    the MSD tach out is a 50% duty cycle 5-18v square wave
    Thanks!!
    Lost Wages, NV
    If it's an Autometer or similar, 12v square wave ideally.
    Keith-
    Cantard 71hallett's Avatar
    snow bank
    gunna hook that bad boy up to your TIG to check it
    Never heard of this...how do you do it?
    Dammit, GN you had me for a bit there. I was out running errands and the "duty cycle" part of your post was rattling around in my head.... I know tach pulses don't have a duty cycle and it finally occured to me you actually did get that off a tig welder...
    Now see if it was a mag, you actually could weld with it......
    snow bank
    lmfao.......now if only the piston would hold still.
    Kinda askin a lot here, don't you think
    LOL...self repairing...that's an idea...!
    Man, you guys are harsh...
    No, actually, I got that off MSD's web site for the "input" for the RPM/tach on a race pak data logger. It said it can accept that signal, and that is the signal delievered by most aftermarket ignitions. I just figured if you had a Miller Sycwave, you might be able to drive it with that. Really wasn't trying to screw with you.
    That's it! I am never posting another blowed piece again. Iam taking a worse beating for a torched piston than Hotbo did for putting 2 bend rods in a brand new rebuild. This is a tough crowd
