Coil Bind
Results 1 to 12 of 12
Coil Bind
    Mohave Valley/Quartzsite
    Default Coil Bind
    Question for you guru's. Was the closest clearance you guys would run prior to coil bind? I've been told in the past you want a minimum of .050" and others say they won't go below .100". What's your take? I'm sure it depends on application so let use the Manley 48s and 47s valve springs as an example, installed at 2.100" and 2.000" respectively.
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Lurker
    NC
    The closer the better.
    Now, of course the benefit directly correlates with how aggressive of a set-up your working with. The more aggressive the cam/lift/engine speed, the more beneficial it is.
    .050 is a good target if you really need all you can get. When getting this close you have to really measure each springs actual coil bind and set-up accordingly. A high end springs wire diameter will vary .005. depending on the number of coils this can greatly change the "advertised" coil bind height. That is why if pressing to the max, measuring each spring is important. Of course, this diameter tolerance will go up depending on the quality of the spring used. Lesser quality springs will have a huge difference between them so you really need to start being careful at this point.
    Also when getting close you really need to be precise measuring and shimming installed height.
    On a good performance deal I would try to stay at .100 max and .060 min.
    Thanks Warp Speed!!! Curious on what everyones thoughts are!!!
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    I agree verbatim with Warp.
    I am sure you do
    Lurker
    NC
    I am sure you do
    Your just jealous cause I beat you to it!!!
    I am sure you do
    LOL...
    not funny....Hey, it's not who you know, it's who you...well, I know YOU know what I'm sayin....
    He's still trying to recover from the hole'd piston.
    Lurker
    NC
    That's exactly what it was. I just had to lash out. But I seeked out some help, and I feel much better now.
    We understand. We are a sympathetic people.
    Chock full of info. Great reading
