filled block
Results 1 to 8 of 8
filled block
    Concord, CA
    Default filled block
    I have a Merlin pro block filled to the bottom of the freeze plugs. Is it safe to run in a jet boat at the lake for extended times? Twin turbo set up so there will be some heat involved.
    Jerry
    Lurker
    NC
    My Bow-Tie block is filled to about the same level and I haven't had any problems. 598ci/950hp.
    Newton Ks.
    That ought to be OK. I think that only covers about the bottom 1/3 or so of the cylinders.
    Might put a oil temp gauge in as a wise move.
    B1 Racing cs19's Avatar
    Quote Originally Posted by billet racing View Post
    Jerry
    yes just watch oil temp.
    B1Racing.net
    Concord, CA
    Default block
    Have an oil cooler to help with that.
    OK, Sounds like its a go.
    Jerry
    If you fill it with wine, it won't care.
    Concord, CA
    Default wine
    And we have lots of that. In fact breaking ground this summer on a new whse. 95,000sqf. That will hold alot of wine.
    Jerry
    Newton Ks.
    He should have plenty of WHINE from 2 turbos.
