Pro Systems Dom vs Holley 4500 Dom ??
Results 1 to 10 of 10
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    Default Pro Systems Dom vs Holley 4500 Dom ??
    Lets here it ! Has anybody used the Pro Systems stuff ? I found a brand new 1050cfm. part # 8896 for a killer deal. It has the same HP body, is it just a Holley that Pro Systems works over ? Thanks for any help.
    TEN THIRTY ONE RCB19's Avatar
    Looks like they rub their magic into the off the shelf Holley. I know Cyclone was running one on his Pontiac but he had some problems with it at a race. Hit him up. Once you go to the dyno with your new motor the calibration will more than likely change from the current setup anyways.
    http://www.prosys12.macwebsitebuilde...seriesdom.html
    RCB
    Quote Originally Posted by RCB19 View Post
    I was going to take it over to C&J's and let John do his thing, but just wondering about them. John likes to build his own stuff but If I bring him this one I will save like $250-300 bucks ! Probably just bug him w/ this tomorrow. I'm just bored on graveyard shift !
    B1 Racing cs19's Avatar
    cyclone has a quickfuel carb i think.
    B1Racing.net
    From what I've seen the guys at Pro Systems are extremely sharp.
    http://www.pro-system.com/
    Default Braswell Carb
    Quote Originally Posted by 76Miller View Post
    You find anyone who has been doing longer or better
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Pro systems does not massage over a shelf Holley.
    They select the throttle plate, main body, boosters, metering blocks ect individually for the specific engine in a specific vehicle. Blueprint everything flow test provide build sheets with rich to lean jetting info.
    None better.
    And.. If you put the carb on something different, Pat will provide everything needed to make it work.
    You'll get lots of opinions on this topic...here's mine. When we were racing drag cars (SBC/glide throttle stopped to a 10.90 index), we started with an OLD 850 from the Carb Shop in Ontario CA (built before the original owner passed) and it was a basic hot rodded 850 and worked great. Over the years, I got talked into trying several botique carbs from a few big name suppliers. All were supposed to be built to our "exact" combination, with lots of big claims and ALL were a disappointment. Most made a bit more top end power (a couple MPH), but struggled with the on/off throttle from the throttle stop. Also, they also tended to run crappy around the pits regardless of tune up. Out of desperation, we put on a stock Quick Fuel 850 on the car, It worked fantastic right out of the box!! No significant top end loss but regained the consistancy we had lost with the high dollar carbs.
    A buddy that also raced fast SBC's opinion is most of these carb builders were focused on big block combo's and really don't understand SBC's. The fact that a lot of the positive comments on the suppliers I used were from big block racers suggests he might be right.
    The only way I'd ever do another custom carb(s) with a $$ back guarentee that their stuff does what they claim it will or they get it back. Otherwise I'm going to use stock Holley HP's or Quickfuel carbs.
    OBTW, though I've never tried them, the guy that does our dyno work speaks very highly of Proform Carbs. He's used them on lots of different combos from street to fast brackets and says he's always able to get a good tune up out of them.
    As with anything racing/hot rodding related, YMMV.
    Senior Member Hallett's Avatar
    Lakehavasu az
    I have had great luck with the Quickfuel carbs on my boat never had any trouble with them. are they the best who knows they work
    great for me . i have herd good things about the pro fuel carbs
    Ludlow, Ca.
    I run split quadrajets on propane
