Gotta change from Mechanical to a Electric Fuel Pump
Results 1 to 10 of 10
    Silverdale, Washington
    Default Gotta change from Mechanical to a Electric Fuel Pump
    Hey folks,
    I've been running one of the Carter 170gph mechanicals on my boat and loved it but now the new motor that will be going in does not have a fuel pump boss so I need to make the plunge and switch my plumbing to an electric pump and regulator (the Carter did not require a regulator).
    Looks like you can spend as much as you want on this stuff and since I'm not made of money, curious what you folks recommend.
    Gen 6 BBC, 8-71 and twin double pumpers.
    The boat is a little 18' Brendella jet where room is at a premium (pic of the old motor below) and I'm not completely certain where I'm gonna fit this thing. The Transom is damn near unreachable and full already with my sparky sparky stuff.
    Thanks a bunch for the advice and recommendations..........john
    Senior Member CP598's Avatar
    Sep 2008
    Default Pumps
    Hi John, I have been using a Product Engineering pump, filter and regulator for about 7 years with absolutely no trouble. Not sure if this is the budget your looking at but they do seem to be a fine pump.
    http://www.productengr.com/
    Hey Vern, how you guys been?? Hope you're thawing out a bit.
    Thanks for the link. The site is semi down so I couldnt check them out but hopefully they'll be up soon.
    Thanks again and you guys take care.......john
    spokane, WA
    John,
    Get ahold of Tony and use the same pump set up he runs on his blown deal. A little more pump than you need but it will be the last fuel system you will buy for that boat if you ever go bigger in the future. Wich we all do!
    Travis
    A little info:
    http://www.performanceboats.com//showthread.php?t=26984
    The Holley regulator # 510-12-704 is a good hi-flow inexpensive reg.
    On the fuel pump if space is at a premium I've heard good things about the Aeromotive in-line pumps.
    Sleeper CP
    Thanks for the tips guys.
    I'm not really a fan of electric pumps but I have no choice (unless I go belt which is NOT in the cards).
    Take care
    spokane, WA
    John I hear you say that a lot.....I am thinking you need a new deck of cards!
    Here is a great mechanical pump that will fuel your needs with no problem!
    http://www.google.com/aclk?sa=L&ai=C....RacePumps.com
    Travis
    Quote Originally Posted by TwinTurbo540 View Post
    Travis
    Definately need a new deck of cards Travis. No way I'm gonna hang with you big dogs this year. I'll just be on the beach and watching. .
    I can't run a mechanical. Gen 6 block with no mechanical fuel pump mounting option.
    spokane, WA
    Thats right you already said that....sorry man! Look around for a used aeromotive belt dirve pump set up, there are not to bad if you can get a nice used one.
    Travis
    Sep 2008
    Hey John, we're doing well, thanks for asking. Try this link.
    http://www.racingcomponents-llc.net/Fuel_Pumps.htm
