PS 89 Ka Pow!
Results 1 to 14 of 32
PS 89 Ka Pow!
    Default PS 89 Ka Pow!
    As some of you know we had a bit of an issue at Parker last November. Seems a rod bolt had had enough torture.....If you look at the pic of the bearing in the rod, you can see the parting line wear where the rod was elongating. Also, one bolt is broken straight, one bent trying to hold on before breaking. The block is toast, the crank junk, shrapnel messed up the cam, and it looks like a 40MM round went thru the tray. The pan had about a 9MM hole in the side but the baffles and such are fine. I'm sure Dooley will hook me up with another tray. Oh, anyone wanna buy 6 slightly used rods and pistons?...........Ray
    LOUD BOATS SAVE LIVES
    ray just as a question was a rod bolt stretch gauge used during engine build and what grade of bolts are they. can you sleeve that block? just kickin the can around here. thanks
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    To bad scrap $ went down.........Ouchie!!!!
    Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
    hey i had five pieces of mallory drop out a crank at rpm and made that kind of mess,had to pull one piece out of the hull with vicegrips.
    Default Torqued
    Quote Originally Posted by flat601 View Post
    The rod bolts were measured prior to use, and again prior to re use when the bearings were re freshed. The bolts were torqued to spec using ARP lube. They are ARP 8740s and had about 25 heats on them. We had an issue of over revving at Blacklake last year when Mike was pitched partially out and matted the gas. The mag kill did it's job and killed the spark, but the motor was headed to a gazillion which meant the piston direction change, without spark, was all on the rods. We ran 10 1/2 heats after that so that may not of had anything to do with this, but it makes you wonder. Also in the mix is a bum rush to get wet at Parker when the ramp was full and the heat was begun without us. Chris Kenner had to cut the course, and come around for the start without the usual lap or two warm up!!. Did that have anything to do with this? We'll never really know, but THAT won't ever happen again. I'm not crying here. There is no crying in boat racing over engine or boat damage. I have another one going together with L19 ARPs. What really pissed me off was the 12 quarts of racing oil I just put in it!!!..............See ya at the races, Ray
    PS; The block was damaged on the back when a ring gear came off a flex plate on the trailer. The shrapnel smacked the cam plug area as well as a freeze plug boss and an oil restrictor was also damaged. The block, IMO is not worth sleeving. I did salvage the billet main caps for future use......
    ray what size motors do you run? looks like your pistons have a high comp ht?
    guess alum rod are out of the question for the endurance style racing you in?
    Default 440
    That one was a 440. The replacement will be 468, and there is a 496 in the works as well. Aluminum rods are not the hot tip for our style circle racing. Nor are the light weight wrist pins as they tend to change shape, bend, and rip out the bottom of the piston.......Again, I aint crying here......Stuff happens
    Ray
    I run 1.240 comp ht piston w/151 wall in my 601 and the new motor is 565 1.120 comp ht w/180 wall pin 4.600 bore piston weight is 575 grams rods are .400 long eagle L19 when something goes wrong i dont cry i paddle.
    Cantard 71hallett's Avatar
    snow bank
    What rods are those?
    Bullhead City, AZ
    Thoughs were Eagles !
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Speedy Member Jetboatguru's Avatar
    Ray, it looks like it was Chris Fault!! No doubt in my head. The Eagle rods are decent but I would not them my first or second choice on the rebuild. Good luck Ray. Im in Newbury Park if you wanna hit up Red Robin.
    Quote Originally Posted by hondo jim View Post
    get a life..... mowe some more lawns. pick up some cans, save your ol ladys welfare checks and get your teeth fixed.
    pictures boat parts
    snow bank
    Quote Originally Posted by Squirtin Thunder View Post
    I have only ever seen 1 other broken eagle rod. Looked just like yours......big end welded itself to the crank.....broke the rod then the part of the rod that was still on the crank smashed around till it broke 1 bolt and bent the other letting everything land in or through the pan. I have never heard of an eagle rod just breaking. One of them rods breaks..... 99.9% bearing failure and/or oil issues. The big end will turn blackish blue and will actually start to melt just like candle wax.
    [email protected]
    Ohio
    I wonder if any other rod could of held up after zinning it like that? What I'm gathering in these forums, is that over reving is REAL hard on rods.
    Tim
    Tim
    It wasn't the rod...it was the bolts and yes, over reving is a killer. Although a decent bolt, the 8740 is their basic bottom line bolt. Anything making over ~700hp, or anything in an endurance application, IMO, needs to upgrade. IMO, the 2000's aren't enough of an improvement to warrant the cost. At that point, might as well get the L19's and never look back.
    It seems that the Eagle rods themselves have proven to be a really decent piece, especially for the $$.
