opinions on cam selection
Results 1 to 13 of 13
    1976 Sanger Flattie Running_on_Empty's Avatar
    Indiana
    Default opinions on cam selection
    I decided to stroke my 454 and I am looking at a good cam selection. Here is my setup.
    Generation 4 bbc 2 bolt main non siamese
    bored .070 using kieth Black Hyperutechtic pistons
    4.250 crank
    Compression ratio 9:1
    Heads are 049 oval port cast iron 2.19 intake 1.88 exhaust stainless steel valves
    What I'm looking for is a cam with a rough idle. The boat will basically be used for recreational purposes, but I want it to compete on the water when racing other boats on the lake.
    I looking into the Comp Thumpr #11-602-4 cam and was wondering if anybody runs this cam and if would be what I'm looking for in my application
    Thumpr Hydraulic Flat Tappet Cam
    Adv/Dur: 295/313
    RPM Range: 2300 to 6200
    Intake/Exhaust Lift: .522/.507
    The boat is a 1976 sanger bubble deck two seater.
    Engine junkie
    Thermal, CA
    I know everyone has there cam choices, but seriously call Engle Cams.
    They turn out quality, not just a shelf piece. Ask for Doug the owner, or Chris they are more than happy to spec a cam for you.
    They have a lot of grinds to work form, and can set you up with the correct springs, and lifters too.
    http://englecams.com/index.php
    By the way, no one here can call out a cam for you without knowing your exhaust set up.
    Life's journey is not to arrive at the grave safely in well preserved body, but rather to skid in sideways, totally worn out, shouting"....holy shit.... what a ride!"
    Indiana
    Bassett Twisties
    Senior Member rorybsst's Avatar
    Quote Originally Posted by Running_on_Empty View Post
    4.250 crank
    Adv/Dur: 295/313
    call john @ bullet racing racing cams tell him what u got and what u want and he`ll set u up. 662-893-5670 and be careful with them KB HYPERS the ring gap on them needs to be a lil bigger then normal.
    Senior Member CK7684's Avatar
    Minnesota
    Go with a roller...
    Senior Member 78COLE's Avatar
    Greenville SC
    Have a friend here on the lake that has the same motor, heads, etc.. you mentioned. He is running a hyd. roller off shelf from Doug Herbert.. .600's+ lift. His heavy layup Hondo runner runs hi 90's on GPS. Combo has been reliable for 3 years of punishment. I can get his exact cam spec if you are interested.
    Engine junkie
    Thermal, CA
    Running on Empty,
    Everyone is going to push the roller issue, it's the best way to go no doubt, if you can come up with the $$ it's worth doing.
    But if you need to go flat tappet I would at least stick with a solid lifter,
    more HP and it's the same cost, just a valve adjustment here and there depending how often you run the boat.
    Solid lifter cam: Engle part #2225 HL 25-26
    This cam runs hard, definitely has the idle your asking for, I have used this cam in a few boats close to your set up, always a winner.
    If your set on a hydraulic flat tappet cam then go with this: Engle part #2225H same cam in a hydraulic profile.
    To see the cam specs: Choose Chevrolet BB on the pull down menu.
    http://englecams.com/catalog/old_catalog.php
    Indiana
    I ended up talking to Mike at Doug Herbert ext. 114....great guy...and they had great prices....it was a nice change of pace talking to someone that actually has a v drive. I would recommend him to anyone.
    Thanks for everyones help....it is much appriciated.
    RLP
    RLP is offline
    yep thats who help me on my solid roller jet boat cam
    Minnesota
    I would definately go solid roller on a BBC. Lifter bores arent always 100% on the money and a roller takes care if that issue...
    I vote for Chris Straub!!!!!!!!!!! You will never look back except to see who you just spanked
    He designs the cam and bullet grinds it You pay for what you get, seriously!
    G H E T T O F O E L I F E
    Quote Originally Posted by 78COLE View Post
    BINGO!!! Doug will call his dad or donny and grind the right cam for your'e needs. Chet Herbert is all I will ever use! M
    Member paradigm shift's Avatar
    Did you end up getting a Herbert cam or what did you end up going with. We want details.
