Speaking of carbs how bout my 800dp
Results 1 to 14 of 22
    Default Speaking of carbs how bout my 800dp
    Marine #9022 does my carb flow like a 750 or 850 or????
    Cantard 71hallett's Avatar
    snow bank
    Just a shot in the dark but I would guess somewhere in between.
    LOL...going out on a limb, there?
    Senior Member SkyHarborCowboy's Avatar
    Nov 2008
    Arizona
    I remember once a Trucker came on the CB asking where Mile Marker 41 was HWY 45 in Houston. No one answered back so I said, "1 mile north of mile marker 40 and a mile south of mile marker 42! You should have heard how much crap that guy received for the next 800 (pun intended) miles!
    Joe
    Thanks,
    Joe
    1988 Commander BBC454 Berkley JE-A with A-Impeller
    cfm
    cfm is offline
    The 9022 is a normal sized 800cfm carb. It is also a pretty good carb for many 450-550hp marine builds and thus why so widely used in the marine performance world.
    See ..at least I'm good for entertainment around here.lol I dunno I was curious because I see proform main bodys for 750's and 850's ...I assumed an 800 was a tweaked one or the other. If I had a chance to trade my 800 for a 950hp, it probably wouldn't be worth the freight or would it?(I need a bigger carb)
    All these Q's about how much my carb flows, and not one said any thing about depression. What know what your carb is flowing? Measure your manifold vac (with a damn good gauge) at WOT and max RPM and look it up.
    [email protected]
    Ohio
    I've been wanting to measure my manifold vacuum. So, what would be a good vacuum gauge? I tried a Summit one that bounced all over the place. Should it be liquid filled? I've seen digital ones also.
    Tim
    cfm
    cfm is offline
    GN7 - he's got a 557"BBC so either carb would be too small in my book. I'll bet he's at 2"HG (or damn near it) at WFO.
    H20MOFO - I am led to believe that the HP series are the better candidates for blow thru, and I mention this because of your want to add Turbo's or etc in some time. I'd call CSU / The Carb Shop / etc blow thru carb people and check with them which would be better for blow thru, if that is the route you are going to take.
    The 950 does flow a tad more air than the 800 and seems to provide a flatter/better A/F curve than the 800's. My opinion as always.
    Then I would venture to guess that his 900 is flowing more that 900, reguardless of the booster style. Look at 2 barrels. A 2300 2 barrel is rated at 500cfm and yet it's just 1/2 of a 600/650 4 barrel. It's not rated at 250 because it's flow at 3"HG instead of 1.5"HG for a 4 barrel. If you want a 2 barrel that flows 500 at 1.5"HG, you need to cut a dominator in half That 900 on that motor, with 2"HG could very well bew flowing over a 1000. Put a 1250 dom on it, the vac falls to 1.2" and it flows more like 1100.
    Hmmm...kina just like a flow bench.
    Yep. I just got done flowing a set of my tricked out peanut ports at 200"WC. CFE's BMF 385 have nothing on these babies. 450 cfm at .200 lift A wee bit turbulant though. But tumble is good......right?
    cfm
    cfm is offline
    Hope you where wearing ear protection.
