Junk Yard 5.3L LS/Vortec Build
Page 1 of 23 1 2 3 4 11 ... LastLast
Results 1 to 14 of 322
    Tower Park Resort, Lodi, CA
    Default Twin Turbo 5.3L LS/Vortec Build
    Going in a 1966 Hallett V-drive. Pulled the engine this past Friday out of a 1999 pick-up. Commencing with tear down and cleaning.
    Get it running, then paint.
Name:	Jeep Hallett Crop.jpg
Name:	JY 5 (1).jpg
Name:	JY 5 (3).jpg
ID:	722169 Click image for larger version.
Name:	JY 5 (4).jpg
Name:	JY 5 (2).jpg
ID:	722185 Click image for larger version.
Name:	JY 5 (5).jpg
    okie, lake Texoma
    Good luck with this Seth!! Looking forward to progress pics
    H8-2-W8
    [email protected] first pass
    Thanks Hass. Gonna try to update with pics daily.
    Got the heads off and pistons out. Everything looks as, or better than, expected except that rod bearing and journal #1 have a minor scratch. Just barely catches a fingernail on the journal. Think it'll be alright, but I'll give it a closer look tomorrow. The rings all move freely and aren't gummed up and faces all have the expected amount of carbon build-up. Lot's of build-up in the intake ports, both in the head and manifold... Ordered valve seals.
    I've never been in one of these engines before this. It's a real pleasant engine to work with. All the bolts come out nice and easy, the gaskets come off so nice and clean that they're virtually reusable. No scraping, no prying, no busted knuckles. The parts and machining quality over the older factory small block stuff is a very apparent improvement.
    Hopefully get the heads apart tomorrow.
ID:	722225 Click image for larger version.
ID:	722233 Click image for larger version.
    Yes. I'm tearing it down in the filthy bed of a pickup truck.
    A little bit about the plan for this engine... EFI, twin turbo, big intercooler. I've collected a lot of parts over the past year, but from here on out it's a shoestring budget. A BIG thank you to Impatient1 for all of his input and guidance on parts selection.
    70mm Turbos 0.81 AR turbine housing
    Cast iron center rise manifolds
    Microsquirt EFI ECU - Super compact (wallet size), boiled down bare bones unit. Batch fire fuel and wasted spark ignition using stock coils.
    Stock intake
    80lb/hr Injectors
    Cam driven fuel pump
    Probably an LS9 cam for the time being
    Maybe vacuum pump (OEM Smog pump)
    Only looking for an 80-90 mph boat and think this should get me there.
    I have a lot of book knowledge about engines, but hands on assembly experience pales in comparison. I'm confident I'll do fine, but if you guys have any input along the way, or see a mistake, I'd appreciate the heads up.
    a.k.a. "Mean Pair" Nice Pair's Avatar
    I want out of Kalifornia
    Shouldn't take more than 2 weeks.
    Skater Tanks - The Real Story > http://fullscreenphotos.com/a3bbc
    2018 Dog & Andy's II > http://fullscreenphotos.com/a6c34
    6-22-2018 Lunch Run > http://fullscreenphotos.com/ad3c0
    2018 Shasta Cat Attack XIV > http://fullscreenphotos.com/a9e60
    5-26-2018 Veterans Day Run > http://fullscreenphotos.com/a67c0
    Who R those guy's > http://fullscreenphotos.com/a150d
    Quote Originally Posted by Nice Pair View Post
    Sounds about right.
    Senior Member Double A's Avatar
    Apr 2010
    Yakima, Washington
    That is going to be a neat combo..boat/engine. Thanks for posting it up!
    Quote Originally Posted by Double A View Post
    Yeah, I think so too. Looking forward to a relatively quiet, reliable, fuel efficient, river cruis'n flat with a little go-go now and then.
    Thanks for the mention Double A
    Heads are apart. Just have to pull the valve seals and clean 'em up.
ID:	722393 Click image for larger version.
    Put a piston in some Chemdip last night and it cleaned up pretty nice with almost zero scrubbing.
ID:	722361 Click image for larger version.
    Just dropped the valves in the Chemdip.
    Member sideways_s13's Avatar
    Dec 2012
    Hermann, MO
    I've been running my 01 5.3L hard now for 4 years. Tough little motors. You'll like it
    '73 Hondo Jet, 5.3LS, Borg Warner S475 "MACHINIST MAKE THE WORLD GO ROUND"
    Apr 2010
    Rocklin, Calif.
    Put a piston in some Chemdip last night cleaned up pretty nice with almost zero scrubbing.
    This is all new to me..are those what they call Bee Hive springs?
    Elgin makes a bbc beehive that works great on ls stock heads and ls7 lifters even on a xr aggressive lobe
    Yeah, I think so. Hadn't seen any in person before and had the same thought when I dug into this. The retainers are pretty small compared to other stuff I've seen. I see performance benefit, but I'd wager GM saw cost benefit. Maybe not...
    Here's a couple, upside down and right side up..
ID:	722249 Click image for larger version.
