block fillers?
Results 1 to 14 of 22
block fillers?
    Default block fillers?
    what are most guys having the best luck with? what brand is the lightest and best? we're 1/2 filling a standard deck bbc up to the freeze plugs and not sure what brand to go with and how much we'll need.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    quickcrete use a 80lb bag mix with warm water sorry couldnt hepl myself
    lol, that's what my uncle's machinist said think i hurt his feelings when i laughed about it. i know some guys use that concrete repair stuff, but i'd rather him buy the block specific stuff
    try ( hard bloc) is the name and can be found almost anywhere on the web
    try www.competitionproducts.com
    http://www.rehermorrison.com/
    http://www.raceeng.com/.............. these people are the best out there . !!!
    moroso also has a version of it
    Quote Originally Posted by flat601 View Post
    rehr uses the hardblok brand?
    ptz
    ptz is offline
    so ca
    Question
    do they still make block rock ?
    i need something that is really gonna reinforce the webbing, this thing will see 30+lbs boost
    Kingman/Golden Vly, Az
    i'm just curious?...what r u building...a rocket ship??
    FastRat
    lake Ouachita AR
    tom i hope you learned your lesson on the last gm blocktell billy to buy a good damn block so there is no problemsif not okay milkshake time again
    adjones419 Wet-n-Wild's Avatar
    Shiloh, IL
    We have used the Moroso block filler in all of our drag racing engines with good luck (Moroso part #35570).
    If this is a GM block, you might as well not waste your time putting it together if you're going to run 30lbs of boost.
    Adam
    Hallett 210
    lake Ouachita AR
    Quote Originally Posted by Wet-n-Wild View Post
    i agreeits a turbo dealio
    Southwest corner AR
    Use a better block or reduce the boose! Hard bloc is in my 2 motors but, it's not that critical on mine! WT
    WT
    WFL Crew!!!
    Hey guys, just reading through the thread, and wondering. What's the advantage of filling the block? Strength only?
    PS> Is this used for drag racing only?
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    I have a brand new Dart block.
    Should I even be thinking of doing a 1/2 fill?????
    Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
