BBC Timing Covers???
Results 1 to 7 of 7
    Senior Member Notalent's Avatar
    Dallas/HB/LBC
    Default BBC Timing Covers???
    For the engine builders who use them alot, what brand are you buying? These Specialty/RPC keep getting worse and worse stampings....need something that isnt going to leak and doesnt have the extra hole on the bottom.....any tips on where to go, or know of another company that uses a different foundry (not sure if thats spelled right) Thats priced right...
    "Pain is a figment of your Imagination"
    Senior Member CK7684's Avatar
    Minnesota
    If I had to do mine over, I'd get a 2 piece one...
    Dallas/HB/LBC
    Looking for some cheaper ones as they will be for all our BBC performance engines....but thata n ice piece for mine I heard they leak alot or a pain in the ass....is this true?
    Tri-Cities, TN
    Quote Originally Posted by Notalent View Post
    I sent you a quote off the other board. Let me know if you want a sample...
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Nechako
    you need a modified oil pan if your using a one piece rear seal block as there mk 4 covers , but like gn7 said hard to beat for the price .
    Strap on the JATO konajet74's Avatar
    Antioch,Ca
    if your running a roller, it's hard to beat this one for the price
    http://store.summitracing.com/partde...1&autoview=sku
    Awesome cover, especially if you have a roller cam! It's easy
    to adjust for fwd clearance & tweak the cam( if you get the
    cloyes adjustable timing chain also).
