Newbie with Banks intercooler question
Results 1 to 8 of 8
    Junior Member schmiddy's Avatar
    St. Charles, MO
    Default Newbie with Banks intercooler question
    Hey everybody, just found this site yesterday, been on OffshoreOnly for years but there isn't much turbo info. This is awesome.
    I just picked up a cheap Banks single carb system and it's got this puny little intercooler on it. I've never even seen another one like it. Does this thing actually cool or should I try to find the larger banks intercooler or an aftermarket one?
    It's going on a talldeck 495 stroker with moldex crank, carillo rods, KB pistons etc.etc. around 500-525hp N/A. CR is 9:1 and I want to run the cheapest gas possible. Also, running a TRS drive so the 5lbs it's set at will be the max I want. Funny, I started off just looking for a set of mufflers to quiet it down a tad, and ended up with this!
    Nice Mufflers I'm sure Obnoxious1 will have your answer on the intercooler.
    #55
    I will be keeping an eye on this one. I have some banks manifolds, and risers set up for waste gates (most banks aren't from what I understand). Anyways are you going blow through or draw through?? Sounds like draw thru
    Quote Originally Posted by schmiddy View Post
    That is a regular single radiator Banks intercooler. The dual radiator is probably preferrable but the small one will probably work for low boost. The turbos are not as much "set" for 5 lbs as that happened to be what they made with the previous combination. Depending on your camshaft, and your 9-1 static compression, and larger 496 cubic inch engine, you may see different results. Plan on running conservative ignition timing (28-maybe 30 degrees), and make certain that you have adequate fuel delivery and pressure.
    Senior Member KLINGER's Avatar
    redlands/ aha quin
    that intercooler is larger than mine! what carb are you going to use? 850 or dominator?
    St. Charles, MO
    Quote Originally Posted by KLINGER View Post
    This is the smallest one I've ever seen, other than one that was on my mom's K-car 20 yrs ago.
    I'll be running it as designed, again, not looking for max power, just an extra 200hp or so, which will be maxing the TRS/tranny to the limit. The guy I bought this from builds big HP offshore engines for a living and he's had this system on 2 of his own boats w/ similar specs in the past 25 yrs, so he's supplying the 850 w/ the correct jets so HOPEFULLY there will be limited dialing in time. We shall see.
    Running a CCams XM278- 234/244 dur and .564-.566 lift. I know turbos like stock cams but I don't see a big problem w/this, esp w/ only 4-6 psi and some intercooling, Thoughts?
    redlands/ aha quin
    Ive got a comp 280 cam in mine and im gonna give it a shot before i swap it out.. i havent gotten mine running yet.. i dont think there is an aftermarket intercooler for these applications if there is i havent seen any yet..
    I've got the same manifold, turbo, ic setup on my 460 ford. Boost is around 8-10 and it made over 700 hp with modified PI heads. The IC is a bit small for the size motor/amount of boost and can become heat soaked but after a solid WOT run all it takes is a short "cruise" to bring everything back into spec for me.
