Checking with hydralic lifters - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 18 of 18
  1. #15
    okie, lake Texoma
    Quote Originally Posted by scott foxwell View Post
    If the rocker starts at 90* to the valve,
    and you lower the trunnion .500",
    then you lower the roller (open the valve) .500",
    where is the rocker now?
    Ratio doesn't play into it.
    OK, I get it, sorry for the stupid question.
    H8-2-W8
    [email protected] first pass
    Not stupid at all.
  4. #17
    Pull the snap ring out of the lifter, pull the plunger, remove the spring, and install 2 #10 AN washers in place of the spring. Put the lifter back together without the spring. You just turned it into a solid with a little room. No guessing about cup heights or "is the plunger moving" It will usually have about .075" of lifter plunger depression. This is your lifter pre-load. Usually equals about .5-1.25 turns of the poly lock, once the spring is back in, depending on thread pitch and ratio. Check with light springs at the valve if you want. Follow the video. Dont forget to put the lifter back together!
    Senior Member mustangmark's Avatar
    Nov 2009
    california
    I use a dial indicator and low tension valve springs to find max lift and piston to valve clearance. Just put the plunger on the dial indicator on the edge of the top of the retainers and rotate the motor till the indicator is at its highest reading to find max lift. With the lobes on max lift, I preload the indicator (about 200 thousands) then zero the gauge and press the valve down till it touches the piston to get my piston to valve clearances. Hope this is helpful! Mark
