Checking with hydralic lifters
Results 1 to 14 of 18
    [email protected]
    Ohio
    Default Checking with hydralic lifters
    All the engines I have built have been with solids. I'm doing a 348 thats going to be a cruiser, but I would still like to check valve timing, push rod length and valve to piston clearance. Any way to do this? It's a flat tappet cam. Thanks
    Tim
    okie, lake Texoma
    Tim
    swap out a couple lifters for solids, just to check/measure, then put the hydraulics back in.
    H8-2-W8
    [email protected] first pass
    Rancho Cordova. CA
    Using solids will work for checking piston to valve clearance, but use the lifters you will be running to check pushrod length and cam timing with light checking valve springs. There will most likely be height difference where the pushrod sits between the solid and hydraulic lifter and will throw off pushrod length readings.
    You can check for proper rocker geometry and push rod length real easy without even rolling the motor over.
    [email protected]
    Ohio
    Thanks guys for tthe come backs. And a big thanks to Scott for the video. Never thought of checking that way. I'll try it on this motor.
    Tim
    Default Fantastic Instruction
    Quote Originally Posted by scott foxwell View Post
    Scott, I just finished watching your video on rocker arm geometry and push rod length. I was a HS/CC shop teacher for many years and want to
    compliment you on your presentation. Fantastic job! Great technical information presented in "easy to understand" language.
    Dave
    Diamond Bar, Big River
    Nice, you made it look so easy even a cave man could do it. Thanks for putting that up.
    Jul 2010
    CAMDENTON MO
    Quote Originally Posted by jetjunky View Post
    Or Ozarks Hillbilly. Thanks for the video.
    Iuka, Mississippi 38852
    Saved the video to my favorites. Thanks.
    Thanks for the nice compliments guys. Glad you're finding the video helpful.
    okie, lake Texoma
    Scott, since the rocker has a ratio of 1.7-1, and the lift is actually measured @ the valve, is lowering the rocker by exactly half of the lift @ the trunion actually perfect? or is it just close enough?
    H8-2-W8
    If the rocker starts at 90* to the valve,
    and you lower the trunnion .500",
    then you lower the roller (open the valve) .500",
    where is the rocker now?
    Ratio doesn't play into it.
    The Right Coast/SE-PA
    Thumbs up
    Scott is the man, and one heck of a nice fella to chat with
    Senior Member howler439's Avatar
    Great vid Scott , wish they had youtube 35 yrs ago .................LOL Heck the local college just got brand new seat cutters (cutting edge tech for back then) and centerless was unheard of haha. Cheers Jim
