892 CID (Check this thing out!)
Results 1 to 8 of 8
    Senior Member sdpm's Avatar
    Default 892 CID (Check this thing out!)
    NEW WORLD RECORD!!!, THIS SAME ENGINE COMBINATION JUST PROPELLED FRANK TAMEZ TO THE QUICKEST NATURALLY ASPIRATED ENGINE,(NO NITROUS) WITH AN OEM AUTOMATIC TRANSMISSION IN THE WORLD!!! HE RAN AN ASTOUNDING 6.38 @ 217 MPH, IN OVER 3000 FT OF AIR, WITH THE CAR WEIGHING 2445 LBS !! CONGRATS FRANK !!
    ANYBODY ELSE WANTING TO ROTATE THE EARTH LIKE FRANK DID, WE ARE OFFERING A SPECIAL
    THE EXTREME PRO STOCK 892 C.I.
    2008 892 CU. IN. ENGINE WITH SONNY'S DESIGN
    5.300" B.S. GM HEMISPHERICAL CYLINDER HEADS.
    2075 NATURALLY ASPIRATED [email protected] 8100 RPM 1410 FT. LBS TORQUE @ 6500RPM
    Special Features:
    *--Sonny's 892ci GM Hemispherical headed engine features Ultra Lite CNC program that weighs 2 lbs less than the 784 ci Hemispherical headed engines.
    *--Sonny's 5.300" GM Hemispherical head has a 1.600" longer bore spacing than the 5.000" GM Hemispherical heads
    *--Four Braswell 2bbl carburetors featuring 2.400" throttle bore feed pistons with 16.0:1 static colmpression
    *--The cam has a gross lift of 1.200" with a 1.85 rocker arm ratio with .685 lobe liftl
    *--The 5.300" cylinder head's intake runner has a volume of 652cc while the exhaust is 212cc which flow 660cfm @ 1.100" lift with a 2.725" valve on the intake and 470cfm @ 1.100" lift with a 2.100" valve on the exhaust
    Sonny's in-house fully CNC ported "Next Generation" Hemi cyl. heads
    SAR Special Billet Aluminum 5.300" B.S. block with 1.100" raised cam
    Bryant billet crank
    BME 426 aluminum forged rods
    Venolia pistons
    Jesel keyed lifters
    1.031" tool steel taper-wall pins
    Federal Mogul "Hell Fire" rings
    Special titanium valves & PSI springs
    SAR shaft mounted rocker system with needle bearing roller tips
    Jesel belt drive
    Daley 6 stage dry sump oiling
    Star vacuum system
    ATI balancer
    MSD cranktrigger ignition
    SAR sheetmetal 4x2 intake with linkage
    SAR/BLP (4) 2 barrel split dominator carbs
    Sheetmetal billet rail valve covers
    Meziere hi-flow electric water pump
    Pro series CSI starter
    Fuel lines with 4 port regulator
    This baby comes complete!!
    ONLY 85,800.00
    YOU SAVE 2000.00 OVER THE REGULAR PRICE
    Now that's an ENGINE!!
    Rancho Cordova. CA
    As Peter Griffin would say....HOLY CRAP!!!
    But why with the 936's coming out now?
    DFW Texas
    I
    I like that 932 cu beast he has . Wont be long before we are seeing 1.000+ CU Motors
    LOl I like that fine print . YOU SAVE 2000.00 OVER THE REGULAR PRICE lmao
    Here you go another pro stock engine , Going from one extream to the other lol
    http://www.steveschmidtracing.com/en...pro-stock.html
    Quote Originally Posted by sdpm View Post
    That's a Condo
    Sleeper CP
    Rancho Cordova. CA
    That's a Condo
    Sleeper CP
    With 8 big rooms!!
    That's a Condo
    Sleeper CP
    I think this engine could take care of that 814ci Ford in the Crapshoot!
    spokane, WA
    Thats my buddy Todd's advertisement, he is a dealer for Sonny's now as well as runs pro stock and top sportsman. The 892 that is in Franks ride sounds like no other!!
    Franks best that weekend in vegas was a 6.38 @ 217 MPH, above 3000 ft of air. Watch for some 6.20's here real soon when he gets it all sorted out!!
    Travis
