Draw thru/blow thru ?
Results 1 to 8 of 8
    Maw
    Maw is offline
    Huntington Beach & Havasu
    Default Draw thru/blow thru ?
    We're planning on converting our PFM twin turbo BBC over to EFI before summer gets here. Plan is to use a Victor Jr EFI manifold and keep the standard large PFM intercooler bolted to it.
    The question is -- do I use a standard throttle body where the carb currently sits (between the turbo's) or add two smaller throttle bodies to the intercooler inlets? A third option could be to add a short four barrel thottle plate between the intercooler and the manifold.
    Any clear cut advantages one way or the other.
    Thanks, Mark
    most twins i've seen run 2 tb's before the cooler. get with unchained, he's yo man to talk to on this already is runnin the set-up you're wanting.
    Ada, Michigan
    You definitely want to blow through the throttle body.
    A pair of them between the compressor and the intercooler or one under the intercooler would work fine. A blow off valve will be required if you like to slam the throttle shut at high boost levels.
    Here's a pic of a Brummett setup with the throttle body under the intercooler,
    A throttle body source,
    http://www.accufabracing.com/
    I have a Victor manifold with EFI bungs I'll sell for $ 125.00
    It has a Dom bolt pattern and is for a tall deck.
    Maw
    Maw is offline
    Thank you for the responses.
    As a general rule is there any perfomance difference between the blow through and draw thru systems?
    I see 2000 hp systems with turbos blowing through a single 850 Holley DP, then look at the early Banks and PFMs drawing through a pair of the same carburetors, while rated for "only" 850 hp. I don't understand the relationship between the throttle area, blow/draw thru, and horsepower (assuming there is an easilyunderstandable one).
    Thanks for the offer on the manifold but this is a standard deck motor.
    Cheers, Mark
    blow thru is gonna make more hp we're building a 496 and hope'n for 1500hp+ on pump gas alone, low boost levels.
    Nor Cal
    Default Blow Thru Vs. Draw Thru
    I have built 4 turbo engines, from carbs to mech. fuel inj. They have all been blow thru. They always performed better than the draw thru systems. ONE VERY BASIC FACT: TURBOS ARE DESIGNED TO MOVE AIR, NOT LIQUID. The compressor impeller does not like the extra burden of moving fuel laden air.
    Ada, Michigan
    Quote Originally Posted by J. Shelfo Sr. View Post
    I have built 4 turbo engines, from carbs to mech. fuel inj. .
    What'sa matter, you don't like them lectronics ?
    Nor Cal
    Electronics were just breaking out when I did these engines, Anyway the dragboat associations did not allow electronic fuel injection!
