Puke tank
Results 1 to 11 of 11
Puke tank
    Bullhead city AZ
    Default Puke tank
    At what rpm do you add a puke tank ? Im thinking about adding one to my ride , but if its not needed why spend the money. Im sure i will top out at 5500 rpm's and thats probably stabbing it here and there.
    454 "B" cut impellor, very mild build.
    i bought new v/c and am deciding on just breathers or all out puke tank set up besides it will make my boat look faster
    Any input on helping me decide would be great........
    Senior Member The Violater's Avatar
    Quote Originally Posted by 2savage4you View Post
    2 big breathers will work just fine. On long runs if the oil temp gets hot you will get more blow by and get some oil residue on top of the covers. A puke tank will eliminate all that. I built one out of a vw sand rail set up, only about a quart large and put a breather on top of it, works great, never really have to drain it but it looks cool and does the job. If you look close at this pic you can see it......
    / The Few The Proud TheBlown
    Put a pan-vac deal on it. It will pull a little vacuum out of the crankcase and the little oil that does go out will be turned to smoke and sent away from the boat and the engine.
    Clean, cheap and easy. - just the way we like em -
    [email protected]
    Ohio
    Do you think a pan-van would have enough draw to work on a set of zoomies?
    Tim
    Bullhead city AZ
    Quote Originally Posted by Wannabe View Post
    Thats a good idea, where can i find a set up for that
    This is what I was thinking, but any issues if he has wet headers. Never used a pan-evac with wet headers...
    Bullhead city AZ
    Good question , that might end up being a big mess..
    i think i will stick with a puke tank...
    Also if you want the option of running muffler inserts pan vac systems are in the way, they have to stick down into the header to draw. Build a small puke tank and mount it right on the motor piece of cake and works great.
    The Man cordog009's Avatar
    East Texas
    Same situation here. Got some new Comp Cams valve covers that don't have holes in them yet and want to do it right the first time.
    1984 Youngblood TX-19 SOLD
    Senior Member Factory1's Avatar
    There was a good thread on this a few months back in the v-drive section. It's probably buried 7 to 10 pages back or so, but I believe it is also simply titled "Puke Tank" . Should help you out, F1~
    Newton Ks.
    Call DuaneHTP either at Hi-Tech Perf, or PM him.
    He has an evac setup on his 1200HP family lake boat (injected Basset Thru-Transoms). Works just fine, be he knows a dam sight more about it than I do.
    H.L. Mencken
