Cylinder head drain back
Results 1 to 14 of 86
    B1 Racing cs19's Avatar
    Default Cylinder head drain back
    On a cylinder head that has crappy drainback or if you just wanted to route the oil back to the pan through exterior lines where is a good place to dump it back into the pan? I see Schmitt is doing this on the engines with the heads I run and I see why. Its a win win situation. So I'm going to do this here down the road, where is a good place to dump it in the pan?
    Here is how Schmitt drills/taps the head, I plan on something similar, probably use screens in the head incase I bust a spring, rocker or something?
    Dumping back into the rear of the pan would be easiest for me but the flywheel is an issue and Im unsure thats a good place.
    Where do you guys feel is the ideal place?
    B1Racing.net
    Schmitts drainbacks. Looks towards the rear of the heads.
    B1Racing.net
    Middle of the pad, above the tray. Been doing that deal for over 25 years on boat motors.
    I was curious about the drainbacks on my AFR's. They are the size of my pinky finger. Not very big at all plus there isnt a place in the middile of the heads to drain like the cast iron BBC heads.
    G H E T T O F O E L I F E
    El Cajon, Ca.
    I run mine towards the back at about #4 main (starter and oil filter boss was in the way of putting it back at #5 main). I also use a scraper and one of the wrap around screens so where the oil drains back it as almost no chance of being picked up by the rods and crankshaft. My Brodix heads come with holes already pre-tapped for 3/8 NPT... they end up being right at the lowest point the oil can collect in the head. You'd be amazed at how much that lil -6 return can actually return once the oil is warmed up... like nearly none actually makes it in the holes that drain back into the valley. Of course this would also depend on how much you send up to the top.
    You have one of those fancy pants kick out pans then I'd say plumb it back into that area... anywhere it can't be picked up by flailing parts.
    The Bostick®
    Thanks for the replys.
    In this pic you can sorta see how the windage screen wraps up the side of the kick out. The more I think about it, I'm thinking about dumping it back into the pan behind the windage screen towards the top of the kick out. I'm thinking that would have the best chance of not getting wrapped up in the crank and rods and it would be above the oil line there.
    B1Racing.net
    Im thinking 3/8 pipe drains and using -8 hose.
    B1Racing.net
    Canyon Country, CA
    good idea
    Quote Originally Posted by Robert Jonsson View Post
    good idea
    Whats up Robert?
    Where do you think the drainback should be in the pan?
    B1Racing.net
    Not too far back, your going to have a wall of oil when you nail it.
    Concord, CA
    Default direction
    We use oil drain backs on the turbo motors. Keep it as high in the pan as possible, and aim it towards a main bearing. Keep it as short, and big as possible. Keep it as straight and down as possible.
    Jerry
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Quote Originally Posted by billet racing View Post
    Jerry
    Yep above the oil level onto a main cap.
    Ended up here (where the red caps are). Its aimed at #4 main, above oil level and behind the windage screen on the kick out side. Will be using number 8 hose. Used some of those trick XRP fittings and o-ringed washers, worked out good. I was going to plumb both on the kick out side to take advantage of the windage sccreen but it would have been hard to keep the hose coming from the far bank on a downward direction so I did one on each side so its easier to plumb. Pans back on. Thanks for the pointers guys and thanks to Robert Jonsson for the help today. I will post more pics when I get the heads tapped, not sure how thats going to play out, the heads are pretty thin where I wanted to pipe tap them.
    Chris.
    B1Racing.net
    El Cajon, Ca.
    If the head is thin then just tap them for -8 (3/4-16) and use an union with an o-ring, with the side going into the head lathed off and tapered on the inside... kinda like a fuel fitting you'd use for a regulator or somehting ... but shorter so it doesnt protrude into the inside of the head... done this a few times and works well... this is what I used for the side that goes to the pan as I didn't have much room for a nut on the inside of the pan... so I just welded a nut to the outside and used a fitting like above with an o-ring... worked peachy.
    The Bostick®
