cam springs
Results 1 to 9 of 9
cam springs
    MD
    Default cam springs
    I'm running a set of AFR springs now that was set at #160/165 on the seat.
    just tested them and they are at #155/160 now. Should I replace them???
    the cam is a HR 242/248 at 50 646/646
    I was just told that they should be set at #125/130 on the seat for that cam
    is this true????
    cam designer said #160/165
    local machinist said #125/130
    Tri-Cities, TN
    If they are Morels I would opt for the 160# seat. 120#-130# is to light with a BBC valve train.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    cfm
    cfm is offline
    5 psi loss is nothing.
    Every HR lifter will be fine with that seat psi. It's the over the nose that can play havoc since theycan be anywhere from 300-400 and more. What is yours ? That's just as important.
    Don't run 130 with that cam unless running low rpms which obviously you won't be.
    Thats a great Comp Cams grind. And easy on the parts. Current spring preasures should get you to 6100 with no float. Run um'. If its the AFR spring I think it is, you will be 410lbs over the nose.
    MD
    Thanks everyone for the help
    Yes they are the AFR springs. Bob Marada (RM Builder) had them set up for his Custom cam. The cam worked great for the Ex. that I was running.
    The spring compressor that I used only went to #400 Will be checking over the nose pressure this weekend.
    New Guy
    Nov 2008
    Plover, WI
    What type of exhausts were you running? Do you know if that kind of duration and lift have reversion problems with a set of Lightning headers?
    Senior Member SkyHarborCowboy's Avatar
    Nov 2008
    Arizona
    Quote Originally Posted by MACHINEHEAD1 View Post
    Which grind would that be?
    Joe
    Thanks,
    Joe
    1988 Commander BBC454 Berkley JE-A with A-Impeller
    MD
    Quote Originally Posted by Sledge Hammer View Post
    Bassett Tri-Y water jacketed. Had no problem at all with reversion
    Bob designed the cam around the headers
    If you have any questions call Bob he is a great guy Marine Kinetics (sp) 585-654-8583
    Pull up Comp Cams Lobe Profiles on the web. Marine Hyd. Roller (High Lift). I like these because they have generous seat timing, great .200 numbers and a good lift figure for the AFR heads to get into their lift window. Area under the curve is where these profiles really shine. All things considered, the best for continuous rpm use.
