Yet another cam ?
Results 1 to 9 of 9
Yet another cam ?
    Default Yet another cam ?
    Is it possible to grind a cam so that it idles "grandma car" style, yet will pull a Berkeley style A impeller to 5500-6000? If so, what compression/heads/combo, etc etc would be needed to pull that off?
    Rancho Cordova. CA
    I think it would require NOS for what you want. Or you need a big inch motor....572 or 632. Will Idle like grandma's car and deliver more power than you can handle. Just pry open your wallet!!
    Colorado Springs
    Turbo cam, have to also have the rest of the stuff!
    Ladera Ranch
    My motor does what you want. 548 Chevrolet.
    New here Beer:30's Avatar
    Bakersfield, CA
    Comp cams has their XFI cams. Still have some lope, but lots of power and a looser lobe-center-angle to allow more vacuum and driveability. Also, as mentioned above, I noticed their turbo and nitrous cams have 112* or higher lobe centers.
    MORE INFO NEEDED:
    Cubes ? Intake ?
    The 565 idles at 800-900 with a lope(slight) and at 1,100 idles smooth, makes 900 hp at 6,300 and 935 at 7,000
    Sleeper CP
    Big Inch Ford Lover
    Nechako
    MORE INFO NEEDED:
    Cubes ? Intake ?
    Sleeper CP
    Big Inch Ford Lover
    nice........and ya it turns a A @ 55-6000 Mr. Prez. i thought you were in Ottawa getting snowed on today seriously thats a awesome engine . what's the compression ratio at ?
    Quote Originally Posted by Canuc View Post
    11.8:1
    Basically an A+ at 6,200 (896 corrected, 825 observed)
    S CP
    Big Inch Ford Lover
    Senior Member cave's Avatar
    Mesa, AZ
    Sound awesome Jon
    Takin it home
