Oil Pump
Results 1 to 14 of 15
Oil Pump
    Senior Member wpy3's Avatar
    Pittsburgh, PA
    Default Oil Pump
    Anyone have suggestions or knowledge about billet oil pumps. I was told I should reallly install one while my 502 is apart but man are they expensive. Are they really worth it to prevent pick-up problems and such?
    The motor is going into a 21 Daytona, river boat. Mild cam (I don't have the part #s in front of me right now) Blower shop 250. Hoping to get around 700hp @ 6k.
    Thanks David
    You might want to explain a bit more about the application, how much HP, RPM, that kinda stuff.
    Currenly running both a Mellings and a Moroso. Switched after having to many problems with pickups. Can't say if it's needed for a lake boat. We race endurance races and the water can get alittle rough and the boat takes a pretty good pounding. Engine harmonics at extended high R's doesn't help either. The two down sides are, they are expensive, and the pick up is where it is, so pan configuration has to what the pickup in that location, and not all of the do.
    Senior Member Hydroguy's Avatar
    Get a Titan and sleep at night or I guess I should say at WOT.
    Pittsburgh, PA
    Thanks for the help guys. Forgot, it's a jet also. The water does get pretty rough at the river, gets a little crazy with traffic and all some days. More fun on the ski then, leave the boat at the dock.
    Titan's are great pumps but crazy expensive. They may be worth it in a top level wet sump motor. For what you're doing, the Moroso blueprinted pump is a perfect choice. It's about $125 and we've run it in several motors. Very consistant oil pressure, anti-cavitation grooves, good stuff (IMHO)
    not to mention that the Titan requires a dedicated pan, and won't clear ANY standard pan steel pan, and most alumn. pans
    The Right Coast/SE-PA
    Question
    ... For what you're doing, the Moroso blueprinted pump is a perfect choice. It's about $125 and we've run it in several motors. Very consistant oil pressure, anti-cavitation grooves, good stuff (IMHO)
    Hmmm, I wonder if it's the same pump (minus the psi adjustment screw)as Melling's MEL-10778C for $89.95?
    Pittsburgh, PA
    I'm guessing Moroso or Melling's both have a good pick-up available also, or should I look somewhere else for that? Going to research them both. And your right about the cost of the Titan, you know when they don't post prices your in trouble.
    Engine junkie
    Thermal, CA
    The Melling 10778C will handle the job IMHO, but regardless of your pump choice if your pick up and pan configuration is not correct the pump is meaningless.
    Life's journey is not to arrive at the grave safely in well preserved body, but rather to skid in sideways, totally worn out, shouting"....holy shit.... what a ride!"
    Quote Originally Posted by SRP1 View Post
    Ditto on the pan and pick-up! Melling can handle most apps if the set-up is correct! M
    ditto on the melling select oil pump, a good pick-up is going to cost you about $80
    Pittsburgh, PA
    Are they the same? One just slightly better? Both sound like a good choice.
    #55
