Stipped Crank bolt
Results 1 to 14 of 23
Stipped Crank bolt
    Member bennyb's Avatar
    Mission viejo,ca
    Default Stipped Crank bolt
    Crank on big blockchevy is stripped. Can this be fixed with the motor assembled? Dad is a machinist so if a jig needs to be made to keep things straight that is not a problem. Thinking either re-tapping or helicoil...
    Appreciate any thoughts.
    Go on get your ass outa here
    Silverdale, Washington
    I'm certainly no wizz kid like these other guys but I've drilled and helicoiled one with no problems whatsover. Good luck........john
    Cantard 71hallett's Avatar
    snow bank
    Quote Originally Posted by Eliminator Cruiser View Post
    Try to re-tap the threads and then install a stud...normaly just the first bit of threads get messed up....treads all gone or?
    San Diego, CA
    I would do some research on helicoil's, there are lots of different applications and I'm sure that you could find one that would suit this application nicely.
    check here www.mcmaster.com just to start
    Mission viejo,ca
    Did the re tap thing but they seem to give.
    cfm
    cfm is offline
    Most (not all) bolts do not go anywhere close to the end of the threads in the crank. Go measure as you may be abler to put a much longer bolt in.
    Did you happen to pull the harmonic balancer without one of those bushings that go in the snout to keep puller from damaging first couple of threads ? Would be the first, or 1 millionth to do that. Doh !
    Engine junkie
    Thermal, CA
    Been there done that, Helicoil works like a charm!
    A small jig would be great to keep things straight, an aluminum collar that slides over the crank snout would suffice. I have had to free hand drill these for others also, it works just be diligent about keeping it as straight as you can.
    While it is a viable idea, I would be careful trying to grab the last few threads in the bottom of the crank to anchor the balancer. You need a minimum of 1/2" of usable thread to torque and hold the bolt properly, the thought of having a balancer come flying off in a boat scares the hell out of me.
    Life's journey is not to arrive at the grave safely in well preserved body, but rather to skid in sideways, totally worn out, shouting"....holy shit.... what a ride!"
    Mission viejo,ca
    We did the longer bolt idea today and decided we didn't like the way it felt.
    I don't care for helicoils, I know a lot of people use them but I just feel safer tapping a new size.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    My buddy did that on his 350, except he didnt put a bolt in the crank at all, and drove the puller right down into the crank. Lucky for him he realized after he killed the first couple threads so he just re-tapped with the same size and had plenty of threads left further down.
    I like the idea of re-tapping bigger, with the crank i cant see a reason why not too, seams like there is plenty of material?
    Mission viejo,ca
    No but if I did I wouldn't admit it
    I'd just go to the next size. Nothing wrong with that.
    I think in '69, the 300hp Taniwanda 350 came with a pressed on balancer. The crank wasn't even drilled for a bolt. One of GM's shining moments of engineering.
    Albuquerque, NM
    Might look at using a Keensert over a helicoil. I repaired a crank with a keensert and ran that motor for 5 years before I sold the boat and never had a problem.
    24' Eliminator Fundeck
    Mission viejo,ca
    Bigblockbill, did you use the thin wall or thick wall?
